View Full Version : Suspension & Brakes
- Civic coilovers on DA
- what should I buy... lca's
- 2 Questions please help (installing lowered springs) on Eg
- installing ground controls with tokico illuminas
- Arospeed
- Best Full Coilovers for 94 Civic EX
- bouncy suspension
- Don't want to lower car, just have tighter suspension
- has anyone tried?
- apexi n1 dampers
- ? rotating tires X, front to back, shocks affect wear
- Ksport pro vs koni yellow + GC, searched, got nothing :(
- cross drilled rotor direction
- lowering question!!!
- Tein SS vs. Ksport/D2's
- suspension compatibility between generations
- Shock top nut- in trunk
- need a write up on coilover installation
- prelude coilovers on civic?
- traction bars
- Ground Control and Stock Struts?
- where/who did you buy your koni yellow/ground control combo from
- is this oversteer of understeer
- Will this work?
- having trouble putting rear lower control arm back in, possibly bent?
- EK suspension techniques sway bar with aftermarket lcas
- Anyone know the diameter of a stock 93 civic balljoint?
- how you can you go??
- torque specs?
- custom hats for wilwood rotors to "space" wheel.
- front shock to match itr rear
- eg and ek suspension swap?
- 93 civic front sway bar with 94+integra front lower control arm?
- Broken perches
- 94-97 H&R Cup Kit for Honda Accord
- Need help with spring rate's. SEARCHED
- k sport kontrol or omni sports?
- 2000 gsr springs on a del sol
- how low can I go on Illumina's?
- Few Questions that ive searched for
- help!!!! GSR F/R conversion on EK
- camber kits????
- Skunk2 pro-series coilovers
- 98 civic lcas
- $10 Harbor Freight ball joint / tie rod seperators, good for our Hondas?
- What do you think about phantom grip lsd
- Full Coilover Suggestion
- tein s tech springs...anything else?
- SiR vs regular EK
- I got a brake question
- Iluminas and ITR sway bars.. Over Kill?!?!?
- NRG H brace w/ K series motor?
- tire fitment question
- Question about skunk2 camber kit and suspension travel
- what is the best and easiest camber kit to install on the market right now??
- Shock Collar
- Before install the Koni do you have twist the shocks to 180 or 360 degree?
- Koni Red RSK Damper Adjustable Kit....
- Just got Illuminas/GC for Crx and ride is horrible.
- which blox endlinks/whats the difference?
- Quick Opinoins
- Honda Progressive Valve
- 93 Prelude uneven front camber - move subframe?
- **Quick skunk2 coilover question.?**
- GC/koni yellow spring rates( EF ppl please)
- coilover question
- H22 suspension setup
- stripped rear control arm bolt
- 92 da camber problem (rear)please help...
- Question on/about preloading
- Which Springs with KYB AGX?
- kyb agx question need help
- DC5R 5 Hub conversion on a EK ???
- body roll problem, what can i do?
- Stuck Coilovers
- Cusco EK C Pillar Bar.
- skunk 2 SHOCKS?!?!
- 5 lug conversion
- A Question about suspension.
- Camber Kit Question..Another one!!
- From MacPherson to Double A-Arm?
- Need Help Determining if my Coilovers are Damaging my Car
- which suspension would u prefer?
- endlinks
- SRR air jacks?
- Buddy Club 1 pc kit or tein springs on kyb agx
- Koni/GC setup, check. Whats next on the agenda?
- NPG Suspencion Kit??
- Understeer Or Oversteer
- koni shocks on 99 civics
- toe diffrence from civic-teg
- sway bar
- koni yellow height adjustment question
- question about tire tucking on 16" wheels???
- PIC REQUEST: BEST SUSPENSION for 99 civic EM1 SiR
- camber kit for ef
- GSR sway bar on 99 civic (searched)
- Ground Control Questions
- Are the Integra Type R rear lower control arms really better?
- Lowering eg back more
- has anyone tryed the skunk2 sport struts?
- Changing springs from neuspeed race springs to OTC Ground controls on koni yellows
- Springs from civic 5gen, to CRX 2gen
- BUDDY CLUB N+ SPEC review
- Another balljoint question....
- 4th gen accord (90-93) suspension under 500
- difference: greasable or ungreasable bushings for sway bar???
- civic suspension on integra? quick question
- i would like to know what kind of shocks to buy
- Honda-Tech special kit password?
- buddyclub coilovers!? how to adjust?
- SKUNK2
- need help...dc2 suspension. sleeve and strut or full coilover????
- D2 Coilover HELP!!!!
- What ride height yields the best handling?
- some questions about traction bars
- Swapping hubs
- Zeal Funtion ? ? ? ? ? ?? ? ?
- How much drop = how much camber?
- DSS axles on the way...what else should I replace?
- Outer tie rod + boot replacement - a few questions!
- Koni Yellow/GC Questions
- aftermarket shocks on stock springs
- Lakewood traction bars any good?
- Ek rear control arms on a Delsol????
- i might buy unles.....
- bumpstop trimming ....?
- ES bushings in aftermarket LCA's
- megan lcas (bushings are trash)
- eibach sportlinespring rate?
- UCA hitting inner fender well
- will my springs and shocks fit on a 1990 integra LS
- Problem with lowered crx. *Pics included, please help
- Best Suspension?
- Squeaking From Rear Suspension - worn bushings?
- Integra rear toe adjustment.
- Trailing arm bushings?
- camber kit??????
- ground control and koni warranty?
- need opinions....
- Cusco Zero2
- omni question
- Hitting the strut tower with a arms, HELP
- Suspension Techniques Front Swaybar ... Help?
- Need Help..95 Accord shock bushing
- suspension help loud pop and spring choice
- Si suspension question
- Annoying suspension squeak. Need help ASAP
- when are new springs required?
- 3 channel Civic vs 4 channel Integra ABS...
- full coilover
- will the tires hit?
- Comptech Swaybar Combo
- Another Sway bar question
- when choosing springs.....
- Integ Suspension
- Installing rear strut bar without cutting into panel?
- drag springs vs performance springs
- Need help identifying tranny problem for DC4
- What should I do for camber?
- suspension on a budget
- Miracle x bar on a dc work???
- Ground Control/Koni Setup
- PASSWORD JDM strut bars
- Sway bar question for my EG on the Tracks
- Rear Toe need adjustment after lowering?
- Supension Setup
- ASR have a contact?
- integra type r trail arm inserts
- Need help with finding Spoon brake parts
- K20a swaped Ek hatch suspension/handeling setup
- can i go lower with these tires?
- top hats
- Off The Shelf Rates for Ground Controls
- will 1996-2000 shocks fit on 1998 integra
- 3-point Front Upper Tie...
- how thick are 92-96 prelude vtec rotors? or other 4x114 rotors
- suspension for ek
- Question for my EG w/ b16
- Will 96-00 Suspension Fit an EF (89-91) CRX
- Best springs for my 99 SIR
- wtb: Specs: TEIN Type Flex Coilover Suspension - EDFC Compatiable Part EDKU1-12120
- 89 Integra suspension
- how do i choose a spring rate?
- CRX camber kit
- AGX shocks and GC coilovers
- kyb agx eg on ek hatch
- need some input
- Caster is off!!!!!!!!!!!please help
- poll on springs
- Extended Studs
- B425F/215R spring rate street/dd
- Please only chime in this thread if you have OWNED GC/Koni, Ksport, Omni, and F&F..not all of them b
- Does this ball joint install look ok?????
- what suspension recomend?
- Lowering = noise?
- how to adjust ride height on jic coilovers?
- 32mm vs. 36mm 5 lug set-up! What's the difference?
- Ground Control spring length?
- coil over
- Tire rubbing question on integra
- Springs for my EG?????
- fixing camber issue
- Rear, Front or Both Swaybars H22 EH Hatch
- What LCA's use Urethane?
- lowering problems..
- Skunk2 sleeve kit with Koni yellows PLEASE HELP
- Front UCA bushings?
- What is this and where is sit supposed to go?
- GR2's and Eibach Pro Kit---I'm loosing my mind, need advice/help :((((
- Wheel Hub Bearing for 98 CX with 5 lug conversion
- Skunk2 Rear Camber Kit questional behavior
- Del Sol suspension for Autocross
- I have $800 to spend on lowering my car. Need expert advise please.
- traction bar problem
- I'm looking for some serious performance. Which brand should make the cut?
- cheapest place to get tein basic?
- I need new suspention, cant make up my mind; help
- Stock '99 Civic EX needs struts, replacing with aftermarket KYB's, do I need anything else?
- Tein Flex 10/7 rates vs. 9/4 rates
- Which F/R camber kit for a del sol?
- Rear Suspension Assembly Problem...Lost few pieces:(..Need help!!!
- What is the best Big Brake Kit for a 15inch wheel on a del sol
- Da5 suspension information please?
- Front Camber Kit... ONLY?
- koni FSD
- I'm newb to making car mods. Can anyone help with my suspension problem?
- the benifits of the bars and arms
- work cr-01
- Sway Bars?
- What would be better to do now?
- 92-95 Civic shocks fit 96-00 Civic???
- Springs make noise.
- tien stechs +____=smood ride
- How to fix rear camber with washers
- 5-lug help!
- just tried to get my car aligenment done? wtf
- Does the Integra F&R calipers fit the 4x114.3???
- Omni street damping!!
- Input on springs for my Kyb agx sturts thanks guys
- steering wheel hubs for DA
- 90-93 Integra Sportline springs on a 93 Civic Ex will they work?
- BLOX CAMBER KIT???
- Koni Yellows + Neuspeed Race springs = bounce
- What fLCA to use for EK...
- When installing GC/KONI do you??
- Camber?
- GC/KONI- Bottoming out?
- BUDDY CLUB drop heights
- Will my Eibach pro kits for a 95 (DC4) integra fit a 98 Civic (EJ8)?
