View Full Version : Suspension & Brakes
- camber kit or bend spindle???
- Will Integra's rear brake lines fit on EK?
- LCA bolt broke
- noise from driver's side area at low speeds... help
- wtf is that noise
- Can Omni Power shocks (coilovers) be mounted longitudinally or in an inverted position?
- f2 coilover question
- Need some shocks to go with the Sprint springs
- ASR question
- what shock/coilover setup would u recomend?second thinking koni/gc
- GSR brake conversion
- K sport question
- OMNI POWER spring rates?
- Uneven camber
- Koni Yellow Internally Adjustable?
- Pic Request EG CIVIC with ASR subframe brace and BLOX LCA's w/ ITR 22mm sway
- Will an EG suspension fit an EK?
- Shock help!!
- Suspension Noise
- carbing strut bar.
- i think its my ball joint
- suspension setup
- Best Suspension? Details Inside
- after SPC upper arm install, car rides Horrible. HELP
- TOKICO ILLUMINAS TOTALLY WORTH THE $500!!!
- Ksport or tien please give info Thanks.....
- What could cause this camber reading? (stock) and other questions...
- Rack and pinion help!??
- help tokico coilovers
- Koni Sleeves!!!
- replace blox LCAs bushings
- Opinions on Suspension Technique Rear Sway on a EG - Also fitment question
- New to suspension...
- What about going up? Options for jeep like baja suspension on a 92 civic?
- crx---ek suspension compatibility?
- Retaining Negaitive Camber Without Kit
- 93 integra rear swaybar on 95 civic
- Where to buy Eibach Pro-Street-S Coilover System
- Bilstein users- Did you get dust covers with your shocks?
- Camber kit differences
- travel
- slight drop & easy ride, whats a good spring?
- S Techs and Illuminas?
- Tokico vs. Koni
- camber kit help
- camber kits?
- The new skunk 2 complete coilover setup.
- TEIN S TECH INSTALL
- stiffness
- Tokico Illuminas, Skunk 2 Coilover Sleeves, and what camber kits?
- FWD 600 hp+
- undecided
- Strut Bar studs
- Eibach ERS Spring length ?
- want to go lower, but the ride sucks. pls help
- Simple Koni Yellow question ?
- I want to lower my car.
- tokico blues??
- knuckles
- What would cause toe problems?
- 93 integra struts fit eg's?
- some questions about lowering.
- CRX shocks into EK hatch
- K-sport AR coilovers problem?
- TEIN EDFC Mounting
- 96 4dr gsr shocks
- Looking for some suggestions on current setup
- HELP! 4x114 on a crx problem
- dust boots...important?
- KYB GR-2 with 8 kg/mm rear spring rate?
- suspension upgrade 01 accord?
- tein basic??
- need help. I need the ID and length/height of your coilover sleeve
- 94 civic coupe suspension
- what are the fundamental of getting the ideal suspension?
- Spring rates? RSR race for an EG???? Searched!
- A QUICK SUSPENSION QUESTION?
- Tokico Coilovers... Should I buy them?
- Tenzo-R Springs with what???
- APEXi N1 type PRO?
- Do Eibach springs make noise?
- HELP!!!CAMBER WEAR
- Dumping my DA even more. Need some advice, and possibly a photoshop
- gsr front lower lca's on 96 civic dx coupe??
- does anyone make billet LCA's for JDM rear suspension?
- bushing help
- running LEFT LCA on RIGHT LCA
- Anyone know the spring rates for CRX/EF Civic Progress springs (non-B series)
- coilover setup
- adjustable blox endlinks
- King "SUPER" Wheel Bearings???!!!!!???
- It's time for a replacement...
- Koni experts please look.
- Opinions on Front Lower Ties
- Are there any Prelude specific upper pillow ball mounts that can be used with yellows??
- adjustable coil overs
- upper control arm how to get ball joint to pop in
- I need help figuring out this rattle
- Can anybody tell me if these are real ground control???
- is this a good buy or not or could i find better prices?
- Looking for some Shocks for 97 Civic
- HEEEEELLLLLLLLLLpppppppp . asapp
- What suspension?
- tein SS springs
- TEIN SS VS TEIN FLEX ON DC2
- upper control arms
- k sport lowering springs
- 95 gsr suspension to 97 civic hatch question?
- 4cyl vs. 6cyl springs
- ride
- Reading GC spring rate.
- Best way to level car height..One side is always higher than the other
- lowering question for eg hatch
- rattling noise
- ball joint camber kit install write-up?? anyone got one?
- Del Sol Question
- Checking ABS on 1993 Civic EX?
- the new guy
- CTR 5 lug vs. ITR 5 lug suspension
- Strange POP in the front end.. Can't figure out what it is
- Ground Control
- My Suspension Setup... Opinions?
- Eibach Sportline good for anything?
- ef hatch daily driver suggestions
- Front wheel squeaking noise
- splash guards and severly lowered!
- REAR LCA BOLT PROBLEM
- 08 Accord suspension HELP
- removin old springs and replacing
- I need help fine tuning my setup!
- Tein Flex Problem...........
- i want to slam
- Tokico and H&R Race
- newb questions
- Aftermarket ITR vs EG struts - performance differences?
- building a 5 lug conversion
- K-sport coilovers?
- ek coupe kyb agx: s tech or h&r springs?
- Strange noise when accelerating/decelerating
- How are my specs?
- master cylinder upgrade on EK?
- ep3 function/form coilovers??
- 36mm axles what are my options?
- Camber Kit Help
- OmniPower Sport full coilovers
- Problems: GC Top Hats
- 92-95 coilover kit will it fit on 96-00 ek hatchback?
- Recommended Spring Rates for a CRX?
- weird steering wheel problem
- Newbie question: How to adjust ride height?
- Noise when turning .. coming from upper Control arm or somewhere close to it
- Trailing arm problems. Ugh.
- Ground Controls on Koni Yellows
- asr subframe bar and beaks lower tie bar?
- PRELUDE TYPE SH SUSPENSION
- Civic s/rack on teg
- Brake Upgrade gone bad, no pedal pressure
- Very new to suspension just wondering about a couple things.
- quick upper ball joitn question.....
- Pulsating Noise..??..axle???
- so Im thinking about just springs and new struts
- custom springs for my bc rs.
- Question for those with aftermarket brake calipers...
- Some questions on rear disc brake conversions
- Illumina/Coilover Help
- help
- suspension squeeks
- best setup for everyday driving
- suspensioneg
- ??? Possible to use GC coilovers for stock type shocks w/ Koni sports????
- I Wanna dump my hatch on the ground... HELP?
- installing coilovers/shocks diy write-ups?
- Suspension on DC2
- Will my Tein dampers on my crx fit my DB8 integra?
- Brake swap for EG
- DelSol owners, current or prior, do these cars truly handle this damn bad!
- help?
- How do I adjust my tokico illuminas?
- 5 lug conversion
- Defective Omni Power Coilover
- d-spec ep3
- shock/damper wear..camber???
- which coil kit would go good for an em1?
- h22 eg hatchback
- shortened stock shocks
- eg to ek omnis
- Acura to civic fitment question
- Corner weights for SoCal HT members
- camber kit, no camber kit...
- Springs or Coilovers
- Need help: Front suspension is sagging
- Skunk2 sport shocks bump stop question
- Anyone running Tokico Illuminas with springs/coils? I got some questions about mine.
- Best Suspension Setup for DD & Street Racing????
- I NEED HELP CHOOSING SUSPENSION?!?!
- Sway bar problem
- need help finding a bolt size of oem endlinks w/ pic
- Prelude OEM top hat orientation..Does it matter?
- Soft riding coilovers?
- Changing my suspension setup
- NRG coilovers
- I need you Help guys
- Progressive-rate springs with Ground Control
- Upgraded Lower Control Arms Vs. Bushings
- Question about changing brakes.
- Front sway bar endlinks Civic ex
- choosing brakes
- Tokico Illumina vs. KYB AGX
- will wish bones reversed make aligment wack?
- Which bushings wear the most?
- Spring compatability?
- Leaking Tein SS
- Some rubbing issues...need solutions please?
- EF front subframe on DA?
- part number for integra tie rods?
- installing coilovers Left/Right(quick question)
- Straight (Linear) vs Progressive Rate Springs
- 1990 CRX Front Camber Kit question
- Best Recipe for Riding Dumped/Slammed>>>Discussion!!!
- Eibach Prokit v. ERS
- Suspension Issue. Okay to drive?
- To low??? With koni yellows?????????????97 civic coupe....
- Need help with picking a suspension please help...
- ebay coil overs Which way?
- oops- this mistake is costing me dearly...
- noob problems with my koni and sportline set up
- Alignment: Toe and Cambe
- SKUNK 2 PRO C
- ksports control pro coilovers
- skunk2 LCA and blox adj. endlinks help 95 civic hatch
- best ride coil overs
- coilover help/opinion??
- Camber kit
- suspension gurus, please help me! tire wear question
- Cupping Tires. What could be the cause?
- need an anti-sway bar
- Lower control arm pivot bolt bung nut
- skunk2 sleeves on stock shocks? anybody? ('00 bb6)
- Name that vibration?
- Alignment After Lowering
- Koni Yellows on Civic Skunk Coils - Will GC's Improve my Ride?
- POLL::: F2 VERSION 2's vs PIC PERFORMANCE P2 SELECTS vs BUDDY CLUB N+ SPEC
- Strut Tower Bars: Beneficial or Waste of $$?????
- alignment question
- Ef sedan Big four-lug (4 x 114.5)conversion???
- Eibach Sportline Vs Tein S.Tech
- civic sway bar bolts
- How are the Tein S.Tech Springs?
- skunk 2 struts
