View Full Version : Suspension & Brakes
- street driving manual brakes
- Coilover Product Review
- my brakes won't lock!!
- What to choose
- suspension question!
- ABS fuse box in 1994 Honda Civic Si ???
- Wheel noise. thoughts?
- vibration- from bad alignment?
- F&F Type 1
- Integra suspension in to 92 civic...will it work
- itr brake clearance
- What is the Ideal ride height for great handling?
- Energy Suspension bushing questions,
- Neuspeed Sport lowering springs on EG
- Choosing new Ground Control Springs, quick question on height of springs. EG Owner.
- UPgrade brake for civic Si 93???/
- 2 questions, any help would be awesome
- WEEEEEE!!!!
- Suspension choices
- swapping suspension
- New to the game of brake line tucks
- Rear sway on '97 Civic LX
- Where can I go to....
- Since KSport is sponsoring this forum...
- can someone guide me to the best DIY for installing koni/GC on a 92-95 civic
- Attn. Hybrid suspension gurus!
- eibach sportline for eg vs dc
- Questions for you guys runing rear sway bar on 96-00 civic w/out subframe brace
- Spring Clocking?
- Buddy Club N+ Dampers
- Wanting to lower the car with coilovers - which to buy (I've searched and read)
- 92-96 prelude rear sway bar question
- uneven coilover causing pulling?
- ASR SWAY BAR
- chasebays/rywire brake tuck kit?
- A few questions on suspension
- Tein super street suspension
- Camber Kit Comparison
- Suspension Creaking
- LF suspension squeaks
- Hardrace swaybar endlinks
- Eibach Anti-Roll Kit
- hardrace product
- Si calipers on DX hatch. What lines?
- Appearance improvement opinions needed: DC2
- 99 SiR 1" Master Cylinder Upgrade Question
- Civic CDM Si / USDM EX(ABS) to CDM SiR rear disc swap help
- Bushing replacement?
- Wider tires on rear of FWD car
- 95 eg sits too low
- 2000 ls back to stock height....?
- Megan Racing Springs
- Easy question
- will a 95 teg rack fit a 99 si
- Function & Form Type 2 or better???
- Way to figure out what springs came from where?
- Possible to Resurface 2 pcs Rotors?
- how do u take off your lower control arms to get the axels out?
- S2000 rotors
- i've searched but this is an opinion type ? here on strut comparison
- help adjusting perches on koni yellow shocks
- best suspension for street and track use?
- Why we recommend rear camber kits without ball-joints
- EK track width specs
- LCA Subframe Bolts
- big brake kit for civic 00 15" wheels
- type r five lug not needed for conversion?
- apexi pillow mount top hats
- Soft brake pedal feel
- ??????????Camber kit Question????????????
- Any way to replace lower ball joints w/o press?
- beaks subframe reinforcement kit any good?
- Ground control koni top hat question
- Koni brake line brackets?
- Integra RTA bushing
- Eg6 With dc2 type r front strut bar
- Blox rear sway bar on my 2000 civic si
- GC n Koni yellow height setting
- Ek4 brakes question
- Blox Adjustable endlinks Question
- weird e brake problem
- brake line w/coupler?
- looking for someone to allign a spfwd car???
- drilled rotors
- Best possible brakes that fit 13" VX wheels?
- wilwood set up for dc2
- Alignment techs, steering wheel alignment won't hold
- CRX Suspension Help, Comments Wanted..What would you do?
- tokico blues and gc top hats?
- 2000 Civic - New Drums/Shoes = chattering!
- best spring/strut combo for b16 swapped ef
- KYB GR-2 w/ lowering springs
- which dampers have a short case?
- 90-93 Integra GC/Koni to a 92-95 hatch? Confused HELP!!
- Shocks to go w/ H&R Race
- pic request...prgress technolgy/
- Rattling noise in the suspension
- Coilovers for my DD
- Raising a 90 HB
- PLEASE HELP rim/rotor problem
- will it fit my dc?
- Can someone explain to me how this is beneficial?
- brake lights aren't going on but tail lights work
- Top hats...again
- weird acceleration feeling
- will i bottom out if dropped at 2.25"?
- Ball Joint Issues
- Clocking RTA Bushings
- Ef radius arm clearance issues
- Slammed ef radius arm clearance
- Question regarding rack end bushing replacement
- Uneven ride
- Getting my first full coilover setup... Opinions needed!
- Does DB8 suspension fit EG6
- brake line tuck
- Correct way to lower car using coilovers?
- If you had $600 to spend on suspension.
- ASR subframe with...
- Koni 3011 for eg6
- f2 type 1 or type 2
- Suspension compatibility question. Help please
- another koni/GC question im planning to buy but I need advice ex. spring rates ETC.
- Question regarding Top Hats for Ground Controls
- rear discs w/abs
- rear brake help
- form and function. is it legit?
- ground controls on skunk2 shocks?
- Rear sway bar/LCA/endlink help
- 1990 crx dx tire wear
- TOP FUEL B + C Pillar Bars : ??
- please a need help??????
- Tire Rubbing/Camber Issue
- koni GC install, did I do it wrong?
- KW Variant 3 on ITR
- Camber Help!
- :: Swapping FROM ITR 5lug to LS 4lug
- Replaced lower ball joints...now steering is very tight!
- Koni Dampers
- Integra MC brake line help
- Lowering springs on stock shocks?
- 1991 Prelude Rotor Nut
- Chassis Braces Do they help?
- Uh, I think Dropzone Suspension labeled my springs backwards?
- Skunk 2 pro S question
- Skunk2 LCA Bushing Removal
- koni shocks...adjustment?
- si sway bar question.
- Help with coilovers
- integra rear brake upgrade with 92 vigor caliper?
- function and form type 1s
- Replacing Blox Bushings
- GC coilovers for SiR
- Alignment Results
- Buddyclub racing spec
- Si endlinks don't fit Gsr sway bar
- GC coilovers or swift springs
- Skunk2 Sport Shock question
- prelude calipers on EG
- buddyclub n+ question
- place to roll fenders?
- Coilover spring replacement
- SWAY BAR
- Skunk2 springs shot?
- koni str.t & h&r oe springs
- help on spring rates!!!
- Maxspeed Coilovers?? Install?
- got an alignment...now what
- Clearing up a myth GSR Brakes vs. Civic EX Brakes
- Suspension newb in need of Honda suspension guru advice
- Upper control arm - Raybestos, Deeza, Beck/Arnley, Mevotech, Dorman, OR Karlyn
- installed pads and rotors, now hearing metal against metal
- Powdercoating Koni Sports...worth it?
- h&r coilover spring rate
- function and form type 1 and ground control???
- Suggestion on EJ8 Setup!
- 99 civic ex lower control arm issue
- Brake Pedal Sinks
- front lower control arm bushings
- accord ground control spring custom spring rates for a cb7???
- Working on coilover setup for a non-honda.
- anyone have 750 lb/in springs up front
- Integra Sway Bar into EG??? Yes or No
- new to the suspension world
- Replacing bushings -- what else to do?
- can springs go bad? car feels "floaty"
- whats the best coilover sleeves to buy?
- alignment ?
- Front suspension issues!
- Spring and shock selection
- hawk hps noise
- 00 GSR: abs delete; how to pass State Inspection?
- 95 Civic Strut Bars/C-Pillar/H-Brace?
- brake problem help!!
- CAR WANTS TO CUT ALL THE WAY WHEN TURNING? ANY THOUGHTS?
- good alignment shop in n.y or c.t
- brembo calipers onto ek9 hub
- DC - EF brake swap
- 205/50/15 front rubbing issue?
- good alignment shop in portland, OR
- rsx types s hubs pressed into dc spindles front and rear for 5 lug swap+brake upgrade
- rear sway bar necessary?
- + + Help me find this bar! + +
- 5 lug conversion question!!!
- Blackworks Racing (bwrusa.com)
- stiffness adjustment.
- GC install?
- 94 Civic wheel alignment
- EG5 Brake Upgrade
- Rear lower control arms!!
- Rear Brake Lines HELP!
- Del Sol Springs/Struts on a DA integra?
- Recommend a suspension setup PLEASE!
- sway bar question
- rsx types s front and rear brakes on a dc integra
- rear sway bar swap
- 24mm front sway bar?
- Wierd problem while trying to set my desired ride height..
- Bump Steer Rear Suspension EM/EK
- LOW BRAKE PEDAL!!!
- koni/h&r sport
- List of EF bushings to be replaced.
- eg drag/street shocks
- Front Strut How To Writeup
- Will a front sway bar eliminate my tire rub issues?
- DC2 ITR rear calipers vs. non-ITR integra rear calipers
- crazy problem w slammed car
- Revised Skunk2 LCA Bushings
- 1986 Honda Wagovan bent axle beam|washer|spindle
- Uneven Ride Height
- Where can I get bumpstops/dust covers?
- Ksport Kontrol, H&R spring/KYB GR2 strut, or Skunk2 pro-s
- alignment messed up again in a month
- '90 Crx Si Front Calipers on '88 Crx HF?
- Skunk2 Coilovers for the civic - used on integra??
- DC2 - Rear Clunking Noise - Any Help??
- Ideal spring Rates and struts???
- EK control arm question????
- HPDE rookie question
- Attempting to change struts 1994 accord (cd5)
- 91 shocks/lowering springs on a 92..?
- s2000 bracket milling question for dc4 application
- Suspension overhaul!!!
- Will em1 suspension fit on a db8
- d2 springs with 16inch rims?
- 94' gsr brake rotors?
- too much toe out need a little help
- EG Suspension
- Megan Racing Coilovers
- shock question
