PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. TEIN SS - EK4 - Question about damping force adjustment
  2. Making stock rear sway bar work with K-Sport lca's on 98 GSR?
  3. knocking from rear suspension??
  4. !!!I cant Roll Dumped Headers drag!!!
  5. cheap dropzone shocks?
  6. Brace Discussion/Theory: Jointed, Adjustable designs VS. Single Piece (welded, non-adjustable) Desi
  7. Skunk2 Ef Front Control Arms
  8. coil overs?
  9. 94 hatch with Tein S TECH Springs & Koni Yellows
  10. Skunk2 sleaves/koni yellows on my rsx (I need help/advice) !!!
  11. Help me choose my suspension!! :)
  12. Budget gurus help
  13. kyb agxs
  14. Anyone riding D2 coilovers on CRX
  15. Setting Suspension Height on uneven ground
  16. Advance coilovers?
  17. Drag/daily driver Application Suspension question
  18. I'm in a bit of a situation....I only have so much to work with...susp. budget guru's...help me out
  19. Camber questions...
  20. Coilovers for dc2
  21. new coilovers
  22. Carbing type 2 for RHD
  23. comfort is #1
  24. rear lower control arm ISSUESSSSSSSSSSSSSSSS
  25. CRX suspension
  26. Opinions on purchasing used suspension?
  27. Alignment Help
  28. need some help
  29. new to hondas.. baby to Suspension
  30. good set of lowering springs?
  31. Lookin into new into new suspension setup and want some input
  32. 94 eg6 needs NEW suspension
  33. Suspension install problem, seized bolts?
  34. alignment problem? Maybe
  35. 88-91 civic/90-93 integra rta bushings the same?
  36. Suspension Help: Spring rates ?
  37. Best set up for street?
  38. need help
  39. Eibach Pro Kit - wierd noise
  40. koni/gc or buddy club n spec?????
  41. Softer Rate Springs for F2 Full Coil-Overs?
  42. tire rubbing
  43. i need help.
  44. can you help identify that i have koni ground controls?
  45. strip and auto-x combo
  46. Dust cover on koni+gc setup?
  47. Tanabe Sustec Pro S-OC Type II Coilovers, are they good??
  48. Removing front LCA/Suspension parts on EG
  49. Throwing out some love where its needed
  50. Rear end can't align?
  51. CRX Tein Basic fit DC?
  52. coil fitment question
  53. Which sway bar to use?
  54. civic help ...!!!!!
  55. top hat help ASAP!!
  56. skunk 2 shocks
  57. popping noise braking = steering rack cylinder end replacement?
  58. losing front but rear planted.
  59. Anyone have info on crossmember swapability?
  60. Koni & coilover sleeve questions
  61. Filling Motor Mounts with polyurethane
  62. can springs go bad?
  63. Cant remove stock springs
  64. Help picking the right set of coilovers?
  65. Squeak/click from rear passenger suspension
  66. 99 civic ex 5 lug help
  67. which would be the best coilover system for me
  68. Skunk2 LCA with Blox adj Endlinks
  69. GodSpeed CoilOvers
  70. tokico for prelude and integra
  71. JDM ITR 23mm Swaybar on EG4
  72. Want to slam my eg
  73. Post your H&R race springs on teg or any other car
  74. 94 Hatch with Tein S Techs and Tokico Illuminas
  75. omni power coilovers
  76. Quick question about koni yellows....
  77. is this right???
  78. Stock rotor sizes...>Tyson input please
  79. 4x114.3 Conversion on my DC (QUESTION)
  80. Another camber question....
  81. Getting a new suspension
  82. front sway bar?
  83. want to replace my front suspension have a question
  84. need help/opinion
  85. Input on susp. combo wanted.
  86. GC/AGX combo
  87. EK9 and DC2-R Springs
  88. coilover kit suggestions
  89. DIYr trailing arm bushing install: Tool, press not needed!!
  90. Problems with rear suspension
  91. NON lowering springs
  92. buddy club n+ or koni/gc
  93. JDM ITR 5 Lug Caliper touching the Rotor
  94. shocks like a full coilover?
  95. blox rear end links
  96. opinions on 1gen Integra suspension
  97. camber kit and bushings
  98. question cant figure out what this noise is.
  99. top hat bushing for Koni Yellows
  100. arospeed coilover sleeves???
  101. turn wheel and spring moves? Stock suspension
  102. GOT NEW COILOVERS MAYBE MISSING A CRITICAL PIECE
  103. Kyb agx w/ H&r or different lowering springs?
  104. Opinions PLEASE!
  105. Wat are the best camber kits for an 03 TL Type-S????
  106. Anyone use the LT 825 hub removal tool.
  107. car shaking...
  108. Using EP3 shock on 99 Si
  109. Koni + GC + GC Top hat, which height should i use?
  110. camber wear problem. HELP ME !!!!!!!!!!!!!!!!!!!!
  111. 5 lug conversion question?
  112. Humming noise when I let off the Clutch in Netural or in gear and speedometer goes up.
  113. ? about Mugen Bushings (Kingmotors) and LCA's
  114. ?? about tien EDFC
  115. What is this and where can i get one?
  116. adjusting PIC Selects, DB7 subframe question
  117. Camber Kit any good?
  118. Car pulls to the right
  119. rear coilovers wont go any lower! *HELP**
  120. EK rollbar into an EG?
  121. how hard is it to spin out*
  122. kyb adjustable
  123. big job ahead of me
  124. dc5 skunk2 noise
  125. Tein S-Tech H-Tech Springs?
  126. How do I know if I've blown an OEM shock?
  127. wheel spacer question
  128. Degrees of Adjustment for SPC/Wicked Tuning/Blox Adjustable Toe Links?????
  129. Koni Yellow Sport Kit Installation
  130. fullbody coils question
  131. Omni Drag - Possible to get just the fronts?
  132. << Strut Buster! (picture) >>
  133. Improving handling while keeping stock ride height
  134. Ground Control coilover spanner wrenches?
  135. I need help with coilovers on my eg hatch
  136. Suspension Set-up Opinions
  137. ASR sway bar kit vs. Beaks
  138. coilovers for my EM2
  139. suspension question...
  140. A few noob suspension questions.
  141. Weird shaking at 60mph
  142. 99-00 SI ebrake cable part numbers
  143. Koni Yellow Help
  144. Eibach Align Kit..
  145. steering wheel to soft..
  146. wierd knocking noise while driving
  147. lowered my car
  148. whats the diffrence between a control arm and radius rod
  149. ebay coilovers on aftermarket shocks?
  150. Suspension Techniques front sway bar
  151. !!!!! Eg front forks and ek front forks !!!!!
  152. slammed with 3 inch exhaust piping???
  153. Suspension theories
  154. Signs of a bent rear LCA
  155. Springs Shocks Struts
  156. are these any good?
  157. Need help diagnosing excessive wheel hop
  158. ebay coilovers vs brand names
  159. coilover revalving
  160. my kyb agx shocks/struts only have 2 adj. turn dials?
  161. need help!
  162. agx
  163. Need help with sleeve overs
  164. 94 accord removal of axle
  165. Need help
  166. KVR 4-piston calipers
  167. Vogtland Springs for 2001 Civic
  168. Type-s Susp into ek?
  169. Gettin new springs, help with a choice.
  170. Going back to stock springs, cut bump stops...
  171. //// Traction Bars by ETD Racing from Tuner Toys! ///
  172. Question about lca's on type r
  173. Which would you choose?
  174. Shock Dyno Graph: Koni Sport vs RACE?
  175. APEXi N1 EXV has are they any good?
  176. coilovers....?
  177. Need help with bushings lube.
  178. Suggestion on suspension for an ek sedan..
  179. Can I "reboot" a ball joint??
  180. BUSHING HELP PLEASE!!!!!!!!!!!!!
  181. Need help with skunk 2 pro s
  182. good or garbage ? ?
  183. polyurethane or rubber bushings???
  184. Need Koni shock parts, best way to get them?
  185. Who sells a FULL KIT of OEM suspension bushings?
  186. jic magic flt a1 blown rears
  187. need help!!!! :scared:
  188. I really need some expert advice on suspension. shocks,struts,springs, upper m kit
  189. lower ball joint question please help
  190. ST brand any good?
  191. What do you guys think about this trailing arm bushing?
  192. Any feedback on RSR springs????
  193. 91 DA suspension.
  194. da rear lower arm in a 88hb std
  195. which suspension for RSX?
  196. need help for installing lower springs in 97 hatch
  197. Camber kit needed when slammed?
  198. camber kits
  199. Threaded Koni shock mount hole
  200. Wheel bearing grease ok for short shifter? or is there better stuff?
  201. 13MM Sway Bar??
  202. DOES ANYONE KNOW HOW SAFE WHEEL ADAPTERS ARE?!
  203. Noob question about Koni & Ground Control
  204. cut springs question
  205. Omnipower Backorder...
  206. quick Shock question! eg compatible with ek?
  207. skunk2 lca with asr brace
  208. omni-power rear lca's
  209. The name of the called "Guess What Brand Shock This Is"
  210. Lowering Springs HELP..ASAP
  211. 4x100 Spoon Twinblock Calipers - are extended studs needed?
  212. OEM rear top hats???
  213. TIE ROD BOOT / POWER STEERING LEAK ? CONNECTED SOMEHOW ?
  214. Stock Springs
  215. lca bolt and nut
  216. alignment is off and knocking noises
  217. Wanted: Trailing arm bushing installation advice
  218. Zeal Coilovers EF/DA ok for DC?
  219. Ground Control Problem
  220. SPW coils
  221. Tire Rod Damaged
  222. Apexi Dc2 Coilovers 16way adjustable Q
  223. Tenzo springs for civic any good?
  224. camber kit adjustment HELP!
  225. does tanabi springs and kyb shocks sound good
  226. Question about an alignment.... toe and caster
  227. 94 Accrod!!!!
  228. 4x100 to 4x114 spacers Has anyone tried these before?
  229. maxspeed
  230. Neuspeed race springs on ek with 205/50/15, will I rub??
  231. Spring rates for skunk works coilovers
  232. suspension for my 2000 tegg
  233. DA rear strut bar
  234. Shaking at 65+ mph
  235. Tokico RAK Coilovers
  236. Are my endlinks on correctly? **PICS** and another subframe brace question
  237. Skunk2 Lowering Springs Chart
  238. ingalls camber kits on a crx
  239. I hate to ask for an opinion, but I'm unbeliveably torn
  240. eg suspension on an EK
  241. Rough Riding CRX
  242. Tokico Blues
  243. Please don't bash, Need info.
  244. HKS HiperMax II
  245. Would this work, GC lowering springs on KYB AGX's?
  246. break-in mileage for NEW coilovers
  247. Upper portion of strut moves inside the top hat
  248. Need some expert advice on tire wear
  249. Proper Sway Bar Measurement
  250. Eibach Reviews?
