PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Rack and pinion
  2. traction bar question
  3. What is this bar for?
  4. Steering Vibrates under braking
  5. What are coilovers?
  6. help me choose a suspension
  7. trailing arm bushing
  8. how can i tell what the spring rate is ?
  9. Wheel rate question
  10. top hat spacers?
  11. Question
  12. drop on 18's
  13. EM racing C-pillar bar question!!!!
  14. lowered pictures
  15. help identify what kind of camber kit
  16. Tein S-Tech spring install question... 97 Civic Ex
  17. Tokico Shock/Spring combo
  18. what Full coilovers have height adjustability separate from spring adj.... ie like tein flex
  19. Function & Form TYPE 2 & 18in RACINGHART
  20. Skunk 2 Pro S Coil over Spring rates for 1989-1991 CRX
  21. Tech5 suspension?
  22. Suspension recommendation
  23. GC tophats w/ Full Coilovers (PIC, Omni, F2, Tein...)
  24. full coilover choice
  25. Sprint springs?
  26. kYB, Tokico, or Eibach ?
  27. Tein, K Sport, or Omni?
  28. h&r springs
  29. Trailing arm and rear disc question, plz help!!!
  30. Outboard CV Joint
  31. Crx/Civic Progress B-series Springs review (pics)
  32. Heads up for those with KYB AGX + coilovers
  33. Quick Question
  34. Lowering spring issues.....
  35. Running non standard length ground control springs on Koni Yellows..Suspension guru's chime in
  36. 95 Hatch Cx/95 teg shock swap?
  37. alignment experts...HELP
  38. Q for those with the Comptech Sway/Tie combo
  39. Coilover Question PLEASE HELP!!
  40. CRX/Civic subframe reinforcement
  41. has anyone heard of Chassis Select?
  42. gr2 question
  43. Differences between 96-00 civic and 94-00 integra koni's
  44. Advantages of a 5 lug over a 4lug?
  45. illuminas
  46. after suspension install and alignment very bad inner tire wear
  47. What do y'all think about buying used suspension?
  48. Alignment after rear disc swap????
  49. Ball Joint, Tie Rod, What Type of Grease?
  50. Need help with spring rates
  51. DIY on installing shock/springs
  52. 95 Hatch Cx shock swap?
  53. Spring compressor???
  54. lowering..camber kit???
  55. CRX engine swap tire wear problems - solution??
  56. Strut Bar for 98 Civic Dx
  57. Advantages of using large hollow bar vs small solid bar?
  58. Best Camber Angle for EK4
  59. gc/koni or eibach/koni
  60. good match for agx's?
  61. IT-R Rear Sway Bar on a GS-R!!!
  62. All 96-00 EK's on F2 Function & Form Suspensions pls POST PICS!
  63. KYB or Koni
  64. Any new feedback on skunk2 shocks for eg/ek how will they do with H&R Race
  65. ASR subframe brace w/33mm hollow sway where to get one?
  66. 22mm vs 19mm
  67. EK OEM rear endlinks. How to tell the difference from left to right?
  68. OMNI POWER full coilover kit
  69. dumb question- will any spring work on a coilover sleeve?
  70. Alignment Experts: PLEASE HELP
  71. Need help. Brake problem.
  72. Illumina wit coilovers
  73. What is the best camber kit for DA integra?
  74. skunk2 coil question
  75. Good Suspension for CRX??
  76. ASR brace necessary on an ek w ITR sway?
  77. nothing fancy
  78. Dream Daily Driver Setup!
  79. rims
  80. Lowering Springs?>?>? BRAND??? 2.5" or 2"
  81. Lowering Springs?>?>? BRAND??? 2.5" or 2"
  82. CUTTING SPRINGS
  83. auto to manul motor mounts
  84. New suspension help
  85. sleeve over interchageability question
  86. Spring rate max. on Koni yellow?
  87. koni yellow problem, help please
  88. wierd thing with koni yellow installation need answer asap
  89. Koni Perches
  90. Tanabe Sustec ADJUSTABLE strut tower bar
  91. h-brace anyone????
  92. Broken rear trailing arm bushings: Dangerous?
  93. BUMPSTOPS
  94. Rear trailing arm bushing Tool
  95. dc integra strut question (paring with s-tech)
  96. OFFICIAL (?): Who manufactures whos Shocks in certain Coilover systems
  97. breaking tie-rod ball joints loose
  98. I need advice on suspension, HELP!
  99. Alignment numbers
  100. clicks coming from the axle or cv shaft dont know
  101. function and form type II or gc/koni yellows?
  102. 89 CRX coilovers on 95 Integra?
  103. Best DA Coil-overs
  104. Anyone here running Progress Coilovers?
  105. springtech shocks???
  106. Rear Subframe Separation?
  107. Help on every Honda OEM sway bar sizes.
  108. Hatch with +36 offset 15x7 rims
  109. flca strut bushing
  110. Looking for the tread on cross members
  111. Ride Height /accord
  112. Need advice on which suspension setup to get.
  113. S2000 rear shocks on EH hatch, GC sleeves with 0600.250.0400 springs as starting point?
  114. how to install strut adjuster dial
  115. Help: with 5 lug conversion
  116. autocrossing
  117. eibach sportline vs. pro-kit?
  118. Alternative Aluminum Pillow Ball Mounts for KONI/Ground control setup?
  119. Tanabe Sway Bar and ASR Kit.
  120. EDFC help. Some questions...
  121. how to use swift springs with stock mounting hats?
  122. 4-ponit front crosmember
  123. Best LCAs with sway bar
  124. Tenrai springs for DC2/4
  125. Want to slam my car on SPRINGS
  126. redoing brake lines? first timer, pointers please!
  127. Dented rear subframe
  128. Has anyone tried King Motorsport's rear camber kit for the 4/5/6G Civic and 2/3G Integra?
  129. Integra Supension
  130. Aftermarket ITR/JDM LCAs or standard USDM Civic/Integra LCAs?
  131. skunk 2 missprint?
  132. Coilovers
  133. Squeaking noise from rear of car?
  134. TSX suspension fit on 03-05 accords?
  135. rattling noise
  136. "Mounting Bolt at Steering Hub"? Questions regarding KW Coilover fitment..
  137. Sub-frame brace question.
  138. NEED ADVICE: TEIN SS setup on EF9
  139. BEAKS EK instructions needed
  140. gc/koni help^<><>^
  141. Tein Basic Coilover Kit for Integras
  142. tien s techs
  143. set-up for DC2
  144. Rust on the shocks.
  145. best street set up
  146. Confusion in Trimming Bumpstops
  147. NEED ADVICE: MY CAR PULLS TO THE RIGHT..HARD!!!
  148. 02 rsx dc5 buddyclub with mounts- will they fit on my 01 civic-ex?
  149. Removing Ball joint
  150. Do I have Bump Stops?
  151. FOR SALE!!!! 06 RSX MEGAN RACING COILOVERS
  152. suspension
  153. type r rear sway bar install
  154. 01 coils on a eg/dc aftermarket strut?
  155. Replacing buddyclub spring, 6k too soft?
  156. IS THIS A GOOD DEAL?
  157. BUMP STOPS
  158. blown struts.
  159. black spoon caliper?
  160. progress vs t1r
  161. please help?? my eg needs struts
  162. brakes?
  163. EF H&R race springs on EG?
  164. need help: front control arm joint
  165. Koni Yellow shock adjustment (w/H&R sport)
  166. complete koni coilovers, on tirerack.com
  167. LOWER CAR
  168. Problem with lower ball joint rubbing brake.
  169. Preload & torqueing without torque wrench
  170. Suspension for dc2
  171. RSX hubs and knuckles on a EG hatch
  172. need help with calipers
  173. Ground control koni question
  174. ok to cut?
  175. Rear Lca bolts
  176. koni/nuespeed
  177. accord question
  178. New shocks but which ones?
  179. **KONI"S
  180. Blox LCAs: How to hook up rear sway bar....??
  181. front sway joint
  182. camber or toe?
  183. Type R 22mm Sway Bar used with Comptech Rear Tie Bar??
  184. 92 civic auto to manual
  185. Rear LCA's
  186. SRR rear swaybar/tie bar combo help!
  187. The reason shocks blow. Mechanics help, interesting argument.
  188. Koni 1150-5010 Coil Over Questions?
  189. Suspension & Camber Kit Recommendation please!
  190. does anyone have any experiance with Toda Fightex coilover setups?????
  191. 4x100 Lug to JDM 4x114.3 Lug
  192. A couple of parts questions (Function 7/A-Spec)
  193. How will 98 Civic lowering springs work on a 98 Integra? (Searched)
  194. bump stops to short?
  195. eibach pro kit reviews
  196. new illuminas dont come with bump stops?
  197. how to identify a 99si proportioning valve, is it really the same as a 96 dx lx?
  198. help a noob out :]
  199. Will these EF gc coilovers work on an EG?
  200. RG JTC N1 for a 90 civic si
  201. Need Help ASAP
  202. help removing springs from strut
  203. how would a car feel with a broken endlink
  204. AGX+GC or KONI+Neuspeed for DD
  205. ground control problem
  206. Spring ?
  207. Any DIY for lower ball joints on an EK???
  208. civic suspension interchangeability
  209. Getting koni's/gc have a question
  210. 00 ex springs on a 89 hatch ??
  211. Half'Shafts Good or Bad ?
  212. GSR: Cusco Zero2 vs. Tein Flex
  213. Is this an eibach or stock spring?
  214. itr master cylinder swap help
  215. 98 civic, what springs do i get?
  216. questions for 5 lug conversion
  217. installing suspension myself, are air tools necessary?
  218. Ground Control Question
  219. DIY suspension
  220. car pulls to the right
  221. ? about skunk2 pro coilover spring rates.... how do i tell?
  222. DIY Caliper Polishing/painting
  223. Cunking noise from suspesion is gett annoying
  224. 98 civic squealing. Brake shoes or brake pads
  225. spring rates for 94-97 accord tein s-techs
  226. quick question
  227. help, skunk 2 coilovers!
  228. ST sway bar kit for 92 dx....
  229. good coilover
  230. what rear struts or coils to get??
  231. 10/9 sprign rate
  232. what would be a decent tie bar
  233. spring rates..help
  234. Mugen Showa?
  235. CTR suspension?
  236. Ingalls camber kit problem
  237. Another lame question.
  238. Simple question.
  239. best place to order some gc's with konis
  240. Tein Serial Numbers
  241. which sway bar kit?
  242. what is the best lower arm bar tie bar
  243. 97-01 prelude SH owners
  244. help on kyb agx!!!
  245. Tire shop removed my bumpstops when installing springs/shocks??? Help
  246. has anyone tried em racing tiebar or jdm
  247. Anyone have experience with speed bleeders?
  248. !Control Arms!
  249. what is the best tie bar
  250. Suspension Guru's Chime in...
