PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. NEED SOME OPINIONS! 92 4 door suspension/steering issues!
  2. 93-97 del sol camber kit question
  3. PIC PERFORMANCE VS AMR
  4. GROUND CONTROL or what ACCORD
  5. skunk2 lower control arm Installation
  6. Progress series 2 vs Function&Form vs GC&KYB AGX?
  7. DA brakes on an eg?
  8. tie rod on backwards???
  9. brakes to the floor... not good... help!!!
  10. how to identify brakes
  11. Need help, 92 civic brake issue
  12. "Racelands" Full Coilovers? your opinion please!
  13. Koni STR.T and Tein S Tech = ????
  14. Trailing arm bushings...
  15. need help finding lower control arms
  16. 96-00 Civic rear sway bar endlink discovery
  17. Need help 96 accord Drums/Shoes install
  18. Total Desired Roll Rate - Wishbone Suspension
  19. benen tie bar question
  20. Reinstalling OEM springs
  21. slammed suspensions questions!
  22. Tein S-Techs on Stock Struts?
  23. Drag Racing suspension set ups for 500whp+ cars
  24. Honda Rear LCA discontinued, what now?
  25. skunk2 lower control arm bushing
  26. Will Stock upper ball joints fit on a skunk 2 camber kit?
  27. sway bar from an eg fit an ek?
  28. Budget suspension setup, your opinion
  29. Loud Suspension
  30. Koni VS Ksports
  31. Alignment results / 2.5" Drop (Skunk 2)
  32. Riding SLAMMED breaking axles? How to Prevent breaking axles?
  33. best shocks to pair with skunk2 sleves?
  34. tein s techs
  35. Front strut tower bar for '92 integra (abs)
  36. Help:Anyone know where to get shocks refilled?
  37. i need yall opinion
  38. GC/Koni problem
  39. opinions on Hawk performance ceramic pads
  40. Suspension Differiences
  41. how do i get the most out of my suspension? help please
  42. Using different discs
  43. help please!
  44. Tire rubbing, Will camber kit stop it?
  45. Massive pulling to the right...
  46. to upgrade or not??
  47. Rear Toe Control Arms and Rear Camber Kit
  48. FTP subframe brace into ek
  49. ek9 rear hub spindles help
  50. Which end-links? ASR Brace, Skunk2 LCA, 22mm
  51. Manual steering rack conv. 94 integra questions!
  52. Koni STR.T's with what lowering springs?
  53. tein s-tech + SOMETHING
  54. Legend Type II Calipers on my Civic ?'s
  55. swapping springs helpppp
  56. civic si 2002
  57. rear megan camber kit?
  58. Warrenty with Koni/GC set up???
  59. Need some good brakes
  60. Why would a remanufactured master cylinder cost more than a new one?
  61. Dropzone full coilovers?
  62. Swapping front and rear skunk2 coilover springs?
  63. coilover setups youd run
  64. lowering my eg
  65. Which OEM brake upgrade?
  66. Purchased an EM1 front sway and I broke an endlink!!
  67. mugen activegate rotor replacement
  68. ASR Subframe Brace
  69. front lower control arm advice please
  70. got alignment and now have a lot more torque steer
  71. ITR 22mm sway bar fit gsr
  72. Need help with suspension...
  73. dust sheild
  74. Best adjustable shocks
  75. brake proportioning valve leak
  76. 22mm rear sway a bad decision?
  77. Caliper importance.....?#of piston, piston size, pad surface area?
  78. advice on my suspension setup
  79. What master cylinder for CRX with Integra disc conversion?
  80. I need HELP!
  81. Looking for some advice on ef suspension layout
  82. which coilover is best for a 4dr teggy?
  83. Tokico shock install question
  84. Recommendations for spring replacement
  85. Progress or Function & Form (f2) Suspension?
  86. Professional Suspension advice needed for Build
  87. Anyone try D2's lowering springs?
  88. Torque Spec Request for Rear Spindle Nut/Torx 50 Bolts
  89. EF Civic Sway Bar Issues
  90. Full coilovers or Springs ??
  91. Koni Sport Suspension Kits for the Integra
  92. the "ride" thread
  93. D2 suspension vs Koni GC
  94. Inland Empire/ So Cal Suspension shops
  95. buddy club N+spec damper vs Koni/groun control
  96. problem with top lock nut on shocks
  97. Shocks/struts review
  98. 05 Civic on D2s
  99. Where i get Koni yellow snap rings.
  100. Skunk 2 troubles....
  101. All Ground controls for koni's have an inner lip?
  102. what shock/struts to get for the money????
  103. i want to have my car slammed! please help me
  104. Driver front and Passenger rear don't work
  105. What's the difference here?
  106. 19mm sway bar and 22mm sway bar. Whats the diffrence?
  107. suspension too tight?
  108. front center roll adjusters mfactory
  109. 99 lx civic gr2 front rear shock install help
  110. need help with my EG please!!
  111. sway bar question
  112. Brake line pliers for pinching the brake line
  113. need advice for my Ef suspension plans....
  114. Which Coilover for the DC2?
  115. newb bump stop question, ride quality?
  116. wilwood Narrow Dynapro for a 97 ek.
  117. 94 accord wagon need help
  118. my new suspension setup!
  119. ground control!!! help
  120. 92 teg springs on crx??
  121. Koni Sp3/Race Shocks
  122. Proportioning Valve Disassembly and Leak Questions
  123. ITR 4x114.3 + 95 Prelude Upgrade
  124. Civic comptech sway/tie hardware kit?
  125. brake pads type which one ?
  126. Konis at the bumpstops after Adjustable UCA install.
  127. Function7 vs. ASR endlinks
  128. Non-koni GC sleeve to be installed on a Koni
  129. EP3 Brake woes. GranSport
  130. 91 accord brake system replacement
  131. skunk 2 pro s coilover rebuild
  132. ITR Front Sway Bar - Anti Roll Bar on EG
  133. Ground control top hat question..
  134. Help installing front struts
  135. What bushing should i get
  136. Legend GS Dual-Piston Caliper on ITR 4x114??
  137. alignment problems
  138. Ebay Extended Top Hats?
  139. My ball joint bad?
  140. Replaced Brakes few months back now needs new pads!
  141. Help! Skunk2 camber kit bolts!
  142. possible coilover woes?
  143. EG rr disc conversion
  144. Help Me Outt!
  145. Brake shields
  146. 4x114.3 Brakes on DA
  147. contemplating H brace
  148. BLOX Competition Coilovers in EG
  149. megan rear strut bar for ef
  150. Squeaking noise front left wheel without stepping on brakes.
  151. slotted rotors or drilled and slotted??
  152. H22 EG civic sitting too high at the back?!?
  153. Does it matter which LCA's I buy?
  154. ep3 with d2 suspension question
  155. Function 7 lca and endlink ?
  156. Suspension Going Crazy. HELP!!!
  157. bad rotors/brakes? need help
  158. Leaving Koni Yellows on full stiff ?
  159. hello les amis,slammed a shuttle pleaz?
  160. what suspension setup for a em1
  161. Suspension help!!
  162. Is there any difference in 88 & 91CRXsi suspension?
  163. Low Budget Lowering Help
  164. First Time brake change
  165. Reason for excessive negative camber
  166. Shock Mount Spacer
  167. Type R suspension Question
  168. tips on buying used calipers?
  169. tired of the alignment shop, I'll do it on my own this time. Q about front toe adj.
  170. 2002 Civic STOCK suspension question, Need Help/Advise
  171. looking for a decent suspension setup?
  172. Excessive caster on 93 Accord... how can I fix this?
  173. alignment prob
  174. alignment prob
  175. bleeding / leak question
  176. tanabe sustec super h springs??
  177. top hats trick on any car?
  178. Willwood on 90 dx.
  179. What would be the best camber adjustment for my DA?
  180. Eibach Sport System? Hows the Ride
  181. Input on Full coilover suspension BLACKWORKS
  182. are koni/ground control ajustable?
  183. ***PLEASE HELP NOOB QUESTION. PUTTIN 5 LUG ON EK AND EG QUESTION.*****
  184. HOw to calculate Spring rate....
  185. question on 96 integra rear suspension!! help needed
  186. Will adjusting camber effect toe?
  187. what springs ??? i no u guys KNOW !!!
  188. Tie vs strut
  189. blox sway bar + adjustable endlink
  190. Powerslot Front / Cryo-Stop Rear
  191. gsr disc conversion issue
  192. Ride height alittle high after sitting on jack stands?
  193. front vs rear springs
  194. what does "loaded calipers" mean?
  195. Need suspension help!!!
  196. Difference in struts EG vs EK??? Help
  197. ---Progress Technology Suspension Sale!
  198. Name Some High End Brands
  199. best rotors and pads for under $150
  200. Coilovers or Lowering Springs.??
  201. Koni/Ground control.. what spring rates are you running?
  202. integra tends to swerve
  203. Dog legging??
  204. Skunk2 Pro Series Ball Joint Replacement
  205. Bad Master Cylinder or Air in Lines?
  206. SHOULD I BUY USED KONI'S?
  207. wierd suspension???
  208. em1 suspension
  209. HELP!!!
  210. Brake pads worn funny...please read and reply
  211. stiff and bouncy suspention question
  212. 03 cl-s coilovers which ones???
  213. fender gap bigger in rear after install
  214. given ~$650 what set of coilovers would you choose and why?
  215. what do you guys think about spoon's brake system
  216. upgrading to spoon front brakes and integra rear disk!!!help.........
  217. so just a build question.
  218. 95 Integra Rs Alignment Problems
  219. How to break in brake shoes?
  220. BEAKS SUBFRAME REINFORCEMENT KIT
  221. lowered car fender liners what to do
  222. Advantage of ITR RLCA vs. GSR RLCA
  223. something rubs and drags my car slow after i lowered it
  224. Car Vibrates between 25-35 mph - NEED HELP
  225. Wilwood
  226. coilovers
  227. Anyone have experience with HT-Motorsports spindles/trailing arms?
  228. Traction bar geometry questions....
  229. wheelhop = bad front lca bushings. traction bar ok?
  230. 4x114.3 Front Brake replacement info
  231. koni/GC VS function form type 2's
  232. New Suspension & LCA's
  233. 94 accord front squeak
  234. Which coilover is the best?
  235. k-sport vs. megan
  236. Camber kit 92 accord help plz
  237. Replacing Front Upper Ball Joint / Skunk2
  238. tick/clicking sound from rear suspension
  239. Possible coilover replacement springs?
  240. Has anyone had any good exp. with ebay brand camber kits
  241. Will GC Sleeves for an EF work on a DC?
  242. RHD ek4/ek9 sterring rack
  243. Lowering on a budget 1992 Civic Dx
  244. 1.3 drop eibach scraping
  245. Steel Braided lines - any reccomendation?
  246. blox control arms quality and camber
  247. **what will dump an EF??**
  248. Password JDM 3 point strut tower bar...
  249. JIC Magic SF-1 Coilovers
  250. Tokico Illumina 5 Way Question
