View Full Version : Suspension & Brakes
- ST Speedtech rear sway bar on 92 cx question
- obx camber kit?
- car seem to pul to the left what can be the reason?
- 99-00 Suspension on a EG CX
- 01' civic LX coilover advice needed...
- Skunk2 camber kit question.
- using 3m window weld to fill in ripped bushings- your thoughts...
- Omni Power Full Coilovers
- some suspension advice please (tokico?)
- sway or E.S.?
- how low is legal
- hear bad rubbing and steering wheel shakes?
- adjusting omni coilovers.
- drag spring rates
- Tokico Illuminas replacement adjustment knobs?
- 2000 Civic Si Suspension
- Race this weekend... easy way to increase rear springrates?
- INPUT ON TANABE S-S COILOVERS
- koni perches...only for stock springs?
- TeinStech w/ 17's EK
- Megan coilover kit
- Just wondering
- Readin up on D2 coilovers.
- New teins?
- Am I correct with this...
- passwordjdm rear strut tower bar
- TEIN Basic contemplation
- budget shocks - Koni Red (specials) vs. Tokiko HP
- need help guys!!! *pics*
- The best price anyone has gotten for tein flex or tein ra
- stupid tein flex question
- Need parts pressed in Los Angeles
- Is this worth the money? Anyone know?
- Opinion of tein flex and EDFC
- Dissapointed in my Tein SS-P
- tein ha
- tokico illuminas, how low of a drop and still ride good?
- ITR suspension on my EF9?
- Quick Review: Edelbrock/Eibach full coilovers on an '01 GSR
- will 92-95 suspension fit on a 91 civic hatch
- How to get.....
- HELP!!!
- HELP!!! oem '93 civic hatchback si (eg6) front sway bar size...
- Comptech Sway/Tie Combo: What Setting are you running (Hard, Medium, or Soft)?!
- are skunk coilovers decent? got some on a theft recovery I just bought
- Tein RA or Zeal B6?
- Apexi N-1 springs(kg/mm)
- koni yellows
- integra springs on ef civic
- Progress springs
- Koni Yellows, KYB AGX Shocks
- Tein Super Street Question
- what would happen
- Progress 24mm ajustable sway bar issue (Heim Joint)
- Extended studs, stock wheels. What lock to use?
- Heavy back bouncing on stock springs ?
- integra front sway bar
- Sway bar w/ Traction bar
- Powerslot Rotors Question
- Accord springs. 94-95 vs 96-97, the difference?
- What suspension to get?
- How long can i go without alignment?
- axle plain with lowering ur car
- sway bar bushing clunk?
- Aftermarket Shocks Required?
- Silk Road coilovers for DC2 Integra...anyone ever try them???
- Integra and 99+ Civic Si rear swaybar endlinks the same?
- Bottoming out the shocks?
- 96-00 Coilover question
- Suspension problems - 90 CRX VT
- TEG shocks?
- integras with tein flexs?
- Neuspeed springs - 92 accord
- Need help choosing Ground Control C.Oers..
- stiff spring rates in the winter?
- 00 ek 3dr 4w disc upgrade? help
- SSR LCA Where to buy?
- New ITR rear swaybar mounting technique
- ITR front swap bar on ek dx, what front lca's do I need
- Got my A-Spec_Racing Subframe reinforcement bar yesterday!!!! :)
- is it my shocks or my lowering springs?
- OEM wheels missing a part?
- Bouncy as hell, what do i do?
- Comptech Swaybar kit w/SRR LCAs???? HELP!
- suspension for prelude
- tein coilovers
- energy suspension bushings... will eg lca's fit gsr lca's???
- KYB AGX Adjustment Damping values (Answers from KYB)
- quick question about top hats
- What Should i do????..Very Stiff Ride !!!!!!!
- Source of rear trailing arm bushing for 1991 Honda Civic DX
- Koni shocks & stock springs??......how is the ride in this case
- type-r chassis reenforcement bar pics pls
- Squeeking noise 00 civic...
- omni power full coilover situation?!?
- upgrading shocks.
- Anyone have experience with ZEAL S6 coilovers?
- SRR S1 rebuilding?
- How to make a DC2 GSR handle?
- what shocks are good for tein springs??????
- yeah, hit a curb
- used rear sway?
- Which swaybars?
- Help analyzing suspension or alignment problem.
- Camber adjustment
- lowering help!!
- Spoon N1 (DC2) owners: couple questions
- Koni Sport Yellows or Tokico Illuminas
- Omnipower sports 12k/10k too harsh?
- Type r suspension
- Adjusting PSI of OMNIPOWER coilover
- Lower Tie Bar???what works
- skunk2 springs on tein coilovers?
- Been tossing some ideas around in my head....
- Powerslot Big Brakes on an '01 Teggy?
- Frequency of Shock replacement?
- need new shocks
- type r sway bar in a del sol. simple question
- camber kit price?
- springs or shocks problems? how to diagnose?
- New springs are noisey!
- INNER TIE ROD HELLLP!!!
- stiffer suspension = damage wheels?
- omni power coliover sleeves
- My first personal experience with a JDM coil-over kit.. .A long review
- Front looks like it sits higher?
- my setup
- New LCA fitment in a DA chassis.
- Suspension question for my lude
- sway bar question
- kyb agx adjust. shocks.... street/track
- Koni RSK
- Assembling Dropzone shocks and coilovers
- Help Removing Coilover Sleeves from Shocks!
- omni power install. brake line mounts?
- A fundamental question that will help my CRX in the rain
- Koni Yellows or KYB AGX?
- ef civic front control arm/knuckle fit in 92 eg hatch?
- Help with omnipower preload.
- Installed Omni Full Coilovers today.....need some helpful advice.
- spring or coilover for my eg coupe
- RE: Suspension Upgrade Questions
- glazed brakes?
- SPRINGS?
- beaks sway bar and neuspeed tie bar
- help with coilover suggestion
- Ground Control spring rates...I can't find what vehicle these are off
- Coilovers = New shocks?
- squeaky sway bar - why?
- question about bolt that goes on top of the tophat
- i need help with my 5 lug setup....
- spring question?
- coilover for drag?
- My Ingalls Camber Kit disappointment
- what part is this called on a shock?
- Honda Civic coilovers
- stock alignment best?
- coilover sleeve question
- ground control ordering?
- Anyone have pics of an EK sitting on tokico illuminas w/ eibach sportlines
- what to clean shocks / coilovers with?
- Weird sound coming from the rear of the car 1995 EJ1 please take a look...
- will 99 civic struts and coilovers fit on 2001 integra ls?
- Will my 99 hatch Springs fit on a 99 sedan??
- Spherical bearings
- 2004 Accord/TL Tokico's
- Suspension nuts chime in. In the market for suspension.
- where can i get a alignment in 626
- skunk2 full coilovers.. opinions pls..
- Missing adjusters for tokico illuminas !!!!!!!!!!!!!!!!!!!
- HR coilover rebuild?
- Sustec SS vs TEIN SS
- NEX SS full coilover/shock suspension
- how much for an alignment?
- two diff brand tires in the front
- are 90-91 crx springs interchangeable w/ 94-00 dc (non-itr)?
- Tanabe Sustec Pro SS on a 97 DC2.....anyone have them???
- K-Sport Coilovers
- 2000 civic Si shock suggestions PLEASE..
- Right rear hop
- dumped on koni yellows, how firm or soft dou set it?
- KYB AGX: 92-95 Civic ARE 8 way adj in rear right?
- Need one omnipower coil over.
- What will switch over???
- Progress lowering springs?
- installing springs
- 10 questions dealing with my suspension set up. All imput appreciated. PLEASE take a look!!!!!!!
- omnipower coilovers question
- Ground Control coilovers with KYB-GR2 shocks
- OMNIPOWER vs. KYB AGX's/GC/NEUSPEED
- 400F/500R or 450F/550R Spring Rates?
- HELP with buddyclub racing spec coilovers
- Which bilstein are these? Need to know asap
- dropzone struts with dropzone coilovers
- Cut springs - Lets hear the stories...
- Road/Street suspension mod
- quik question about perching koni yellows
- 8k/6k, switching setups?
- 2000 honda civic Si suspension
- Replaced F upper arms, now back end feels loose
- who daily drives with traction bars?
- Quick Question about H&R Race and Koni Yellows
- Do I need a camber kit with my Tokico Illumina coilover kit?
- Civic springs... Could use some advice
- Good place to buy Ground Control upper mounts?
- do i drille to install a strut bar?
- Annoying crx suspension problem...
- camber settings?
- Which Springs go in the front or rear.
- Relocating brake "valve assembly" (91 CRX Si) Q's?
- eg caster question
- KONI Yellows w/ Neuspeed springs vs. TEIN Basic Coilovers
- to SPC lower control arm owners
- gsr sway bar size?
- I hit a curb again!
- Suspension Problem
- Zeal Function B6 REVIEWS.............
- Are Skunk2 Coilovers any good or is Tien S-tech Springs better?
- what goes first?
- Ground control front and dropzone rear
- Tearing frame?
- suspension techniques springs
- maximum drop while still being able to obtain close to OEM caster, toe,camber,etc?
- new suspension set up
- Will adding weight to my civic make my lowering springs settle lower?
- Integra Suspension help.
- help on suspension purchase
- type R rear sway bar onto 00si...
- '00 rear sway bar onto a '00 hatch - what do I need?
- H&R with AGX or TEIN with GR'2?
- comptech sway/tie bar problems on RSX? HELP!
- Lowering a car for a fat guy :o
- megan racing bars and lca's any good?
- Need to replace dangerous suspension.
- Feels and sound like Thumper is on the otherside of my firewall/floorboard
- what camber kit for koni agx's w/ lowering springs
- "dead spot" in steering...pls help!
- Koni Yellows + Ground Control Coilovers
- yay i just won brand new kyb agx for 230.00 for my integra
- rear coilovers sleeves need help
- metal twisting noise when going up driveways
- what to buy for a da
- Should I use wheel spacers all around?
- Yur ignerance...might be relieved somewhat...by a good shaking...
- Teg springs
- Wheel stud/ Hub Removal Help Please searched
- So how do you select proper spring rates?
- Uhh, what the hell is this?
- Suspension Technique swaybars?
- Anyone ever brought TEIN w/ custom spring rates?
