Car can feel EVERY bump in the road...
I just bought a used 2000 Honda Accord EX V6 Coupe about 2 weeks ago.. The car is in excellent mechanical and cosmetic condition, but the only real problem I've had with it is that I can feel every bump in the road pretty harshly... what can I do to reduce this? Will lowering the car + getting tighter shocks help me out? And the big question.. for a decent job how much am I looking at?
Re: Car can feel EVERY bump in the road... (LegendarLee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LegendarLee »</TD></TR><TR><TD CLASS="quote">I just bought a used 2000 Honda Accord EX V6 Coupe about 2 weeks ago.. The car is in excellent mechanical and cosmetic condition, but the only real problem I've had with it is that I can feel every bump in the road pretty harshly... what can I do to reduce this? Will lowering the car + getting tighter shocks help me out? And the big question.. for a decent job how much am I looking at?</TD></TR></TABLE>
if you get aftermarket suspension, its meant for "stiffness"
double check to see if the car already has a aftermarket suspension...
if so buy a set of OEM honda shocks/springs and you should be good.
Re: Car can feel EVERY bump in the road... (Mike813)
when i bought the car it was all stock.... i bought it from some older lady that was going through some type of "i need to look younger" crisis.. then she got pregnant =\... it's just really annoying when i turn a corner or see a small bump and my car really makes me feel it.. maybe it's just 'cause i'm the driver? i've gone over the same roads before as a passenger ( before i got a car) and i don't really remember bumps...
but.. how much and what would i need... to feel a bit of a "tighter" ride.. especially when rounding corners..lowering my car?
lowering the car well will give you a lower center of gravity and will feel better in the turns, but it will definitely be stiffer. you could also get strut bars that will help reduce body roll, resulting in a tighter ride
Re: Car can feel EVERY bump in the road... (propwdialogue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by propwdialogue »</TD></TR><TR><TD CLASS="quote">lowering the car well will give you a lower center of gravity and will feel better in the turns, but it will definitely be stiffer. you could also get strut bars that will help reduce body roll, resulting in a tighter ride</TD></TR></TABLE>
and what it have to do with ride quality?
if the car is in stock form(assumping it's in good condition), and you complaint it's riding harsh, may i ask what kind of car you used to drive?
Former Sponsor
Re: Car can feel EVERY bump in the road... (EVO 8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVO 8 »</TD></TR><TR><TD CLASS="quote">I can feel every bump on the road too, of course I do have an evo</TD></TR></TABLE>
uuummmm, I wonder why. You know that it isn't supposed to be that way right?
Re: Car can feel EVERY bump in the road... (-Bionic-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- »</TD></TR><TR><TD CLASS="quote">
uuummmm, I wonder why. You know that it isn't supposed to be that way right? </TD></TR></TABLE>
are you saying that evos arent supposed to feel every bump on the road?
Do you own a Honda?
Do you own a Honda?
New User
1 Post
Re: Car can feel EVERY bump in the road... (Confuc1ous)
back to the original question...
this problem could be anything from poor tires to worn out springs (though unlikely)...what kind and size of tires are you using?
you need to check the tire pressure, then check their wear, then from there check whether or not they are the recommended for the car...
as far as springs and shocks, you really think they could have gone so fast? whats the mileage on the car? didnt you say you got it from an old lady?
Of course I know that, I was being sarcastic
Former Sponsor
Of course I know that, I was being sarcastic</TD></TR></TABLE>
So was I
So was I
Young L
02-10-2007 04:48 PM
