92 Accord w/ H22 swap...got some questions!
Ok my friend about a week ago swapped in a H22 into his 92 accord...Ever since he putthen engine in, His car was throwing 4 codes and he took it to a shop and a good honda/acura mechanic we all know told him what to do to fix the problems. Well its still throwin codes and will not go into VTEC and the rev limiter kicks in at 6500...the bad luck continues...2 nights ago he's driving home and at a stop light his car shuts off and won't restart. It cranks but will not start...he gets a guy to help him push his car from outta the intersection...as he's lookin over his car and under the hood, he pulls out his plug wires and finds each cylinder filled with oil and covering the plugs! WE NEED HELP! any know of anything that would help us fix any of these problems?
Re: 92 Accord w/ H22 swap...got some questions! (Pjct2ndGenTeg)
The oil problem is easy. If the only the tubes are filled with oil then its just the seals that go on top of the tubes between the valve cover. Easy to replace. But, you want to find out if oil is getting in the engine. If it wasn't smoking then it wasn't getting into the cylinders so your fine. As for the rest of the problems, who did the wiring on the engine? Are all the sensors hooked up? Which ecu are you using?
It is ecu problem. I should say wiring problem.
I have the same problem for a while, since I mess wires up when I was installing the vafc.
