Best rear camber kit for 1995 Accord EX V6 ?
I need to know a good camber kit for the rear of a 95 Accord V6. I see there are some that are just the kits you put in and some offer the entire control arm or what have you. Im not looking to break the bank but would like something decent that will do the job to fix about a 2.5-3 degree negative camber.
Thanks.
Thanks.
Re: Best rear camber kit for 1995 Accord EX V6 ? (RATEDR)
you can either jus get a couple washers and take the 2 bolts that hold hte control arm on and put the washers in, ususally you can only fit like 3 or so, depending on the width of them. thats what i did and it only cost me like 50 cents at any Lowe's, Home Depot, or any hardware store. Also you could buy a longer bolt of the same size as the Honda one and put however many washers you want in there to correct it enough.
Re: Best rear camber kit for 1995 Accord EX V6 ? (AVcTcEoCrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVcTcEoCrd »</TD></TR><TR><TD CLASS="quote">you can either jus get a couple washers and take the 2 bolts that hold hte control arm on and put the washers in, ususally you can only fit like 3 or so, depending on the width of them. thats what i did and it only cost me like 50 cents at any Lowe's, Home Depot, or any hardware store. Also you could buy a longer bolt of the same size as the Honda one and put however many washers you want in there to correct it enough. </TD></TR></TABLE>
very true, smart idea
depends on how much camber is needing to be corrected. but yes that will work
Re: Best rear camber kit for 1995 Accord EX V6 ? (Confuc1ous)
correct but it isnt exact. its not a washer per degree. so if you are dropped 3 1/2" and have 6 degrees of camber to correct you will want to do a rear camber kit.
1 Post
Re: Best rear camber kit for 1995 Accord EX V6 ? (bagged93accord)
who is dropped around 3 1/2" ?!?!?!.....oh yea, you
OT: my agx's and sportlines are FINALLY getting installed next week
Re: (Confuc1ous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Confuc1ous »</TD></TR><TR><TD CLASS="quote">ok i got it, its not an exact science, so basically its trial and error, ****, yea, get the kit, it takes out the hassle...</TD></TR></TABLE>
but the washers are a hell of alot cheaper
Re: Best rear camber kit for 1995 Accord EX V6 ? (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi »</TD></TR><TR><TD CLASS="quote">who is dropped around 3 1/2" ?!?!?!.....oh yea, you
*cough* 7" *cough* cylinders + body drop = oWnz j00
Re: (Confuc1ous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Confuc1ous »</TD></TR><TR><TD CLASS="quote">one of my accords is sitting on a drop that low, and **** a camber kit, i drive that bitch maybe 1000 miles a year, lol</TD></TR></TABLE>
My 19's wouldnt clear the rear fender if i had a camber kit back there
Re: (Confuc1ous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Confuc1ous »</TD></TR><TR><TD CLASS="quote">my set of 18 inch tires and wheels are the biggest i went, here in NJ the roads suck... </TD></TR></TABLE>
same here in Oregon, but i have the luxury of trailering the car everywhere
Re: (Confuc1ous)
if you really think about it, the back of a car doesnt have enough weight to worry about ur tires wearing down. If you correct the camber to where its alot straighter but not positively cambered, you wont have any problems. It takes 100 times longer for rear tires to wear down like front ones because there is alot more weight to worry about in the front. I put (3) 1/8" washers on my Accord and my wheels are not perfectly straight, but its ALOT better than what it was before i did it.
thats a good point, the weight ratio in comparison to the front is a lot less, but i guess to play devils advocate and sound ****, to not have the tires wear unevenly at all, you think that the washer trick really works? (this question isnt my opinion and i totally agree with your previous post but im asking for those who dont want to)
if you have more than 3 degrees yur really dropped, never seen or heard of 6 degrees, if you got it post a pic. I've worked on hondas since 1990.
hey man email my friend at... Sales@rimsandthings.com he'll hook you up cheap
a rear kit shouldn't cost more than 50 bucks, and you can do it right!! and not do a redneck job and use washers. unless you like to buy tires all the time. don't forget to get the suspension aligned at the tire shop.
Fuster_Cluck
02-04-2004 09:20 AM
b16_madman
01-11-2004 01:31 PM
Haze187
03-17-2003 08:10 AM
