91 2.2 timing marks for balance shaft?
i've got a big chilton manual, but it doesn't show the mark worth crap for the balance shaft on the right side. anyone have a pic or link to a pic? thanks.
Re: 91 2.2 timing marks for balance shaft? (civicwagonman)
I will try to get my Haynes manual, and scan the pic. If you have access to a Haynes manual, I would buy one. They have a very detailed section on timing belt changing.
Look on the gear and you will see a dot on one of the teeth. Then look on the block right next to the balance shaft gear at approximately the 4 o'clock position. You will see a small diagonal line. Line up the dot on the gear with the line.
central_driver
01-12-2009 07:05 PM
