Intentional Open Loop Mode
Old Sep 3, 2008 | 05:47 AM
accord2nrz's Avatar
Default Intentional Open Loop Mode
I know that open loop only occurs during WOT or extreme engine loads. Is there a way to force open loop all the time for tuning purposes?
Old Sep 3, 2008 | 06:07 AM
GhostAccord's Avatar
Default Re: Intentional Open Loop Mode (accord2nrz)
Yes it is possible. If you have a tunable EMS/ECU.
I know that both Crome Pro and eCtune rom have the disable closed loop for tuning capability. I'm sure the rest of them probably do as well.
Old Sep 3, 2008 | 06:11 AM
accord2nrz's Avatar
Default Re: Intentional Open Loop Mode (GhostAccord)
problem is I am using a Greddy Emanage Blue unit. So i dont believe it has that option. Is there a way to mechanically force open loop? I am adding fuel via injector control, but the damn ecu is taking it right back out.
Old Sep 3, 2008 | 07:33 AM
radiuslight's Avatar
There is a way!
I have a stuck on open loop IAC that I removed from my car awhile back.........I'll sell it to you............jk
Nah I dumped it in the alley awhile back!I bet that would of worked well RPM was high too 1600-1900
Old Sep 3, 2008 | 07:34 AM
I'm not familiar with the Greddy unit so I'm not sure how it works. If it is a PGMFI tuning tool it should have some way of controlling the O2 sensor readings going into the factory ECU in correlation with the fuel injector control.
Have to wait and see if someone else can chime in that knows more about the blue box.
Old Sep 3, 2008 | 10:19 AM
accord2nrz's Avatar
Greddy did make an 02 sensor adapter than stops the signal from going to the blue unit at a setable RPM. I might as well go ahead and buy it as it seems that's what I need to tune at WOT.
Until then I converted a GM 2 bar map sensor so the ecu can read going into boost.
mrx
Engine Management and Tuning
May 16, 2015 10:19 AM
Treyschls
Dec 8, 2014 02:34 AM
Ricey McRicerton
20
Dec 24, 2004 12:31 PM
JM Performance
Feb 26, 2002 04:48 PM
Atiyeh
Jul 14, 2001 07:10 PM
