Light Issue
Old Sep 11, 2008 | 05:30 AM
gqstatus05's Avatar
Default Light Issue
Have a 96 LX
I notice that at night (obviously) I turn my car on and my P, R, D, etc lights are not lit. I have to bang it once to get them to light up. Does anyone know what the issue could be? I 'm guessing loose wiring somewhere. Maybe fuse related? Probably not because then it wouldn't light up at all. Right?
Old Sep 11, 2008 | 06:09 AM
dtapia's Avatar
Default Re: Light Issue (gqstatus05)
their is are bulbs that need to be replaced.
Old Sep 17, 2008 | 05:55 AM
dewsbert's Avatar
Not sure if they are the same but, had headlight problems with my 97. Daytime running lights not working, high beam sometimes, usually only one light. chimes at odd times, ect. Found nothing wrong with the wiring or relays. Finally after much digging, ripping and tearing, cursing, found a relay under the driver side dash, hidden by the steering shaft. This is stand on your head access. Found a grey box about 2"x3"x1". inside was the control relays for headlights. Had to use a 10x magnifier to see that most of the solder joints on the relays had broken connections. Used a fine soldering iron to redo the connections and all problems went away.
Old Sep 17, 2008 | 08:16 AM
gqstatus05's Avatar
Default Re: Light Issue (dewsbert)
I'll look into that. Not to annoying yet but don't want it to get worse.
john bolin
Apr 18, 2018 02:09 PM
FeedBack159
Honda CR-V & Element
15
Feb 25, 2014 06:42 AM
Novz
Honda Civic (2006 - 2015)
Nov 8, 2013 04:34 PM
Turbolude96
Nov 21, 2012 07:59 PM
dagle
Oct 17, 2007 09:43 AM
