Engine & Steering Shutter Issue
Old Sep 5, 2008 | 05:04 AM
NGUSPEED's Avatar
Default Engine & Steering Shutter Issue
Good Morning HT,
I have a '96 Accord LX Sedan w/ 5spd Manual Transmission, 121k mi, Stock F22 w/ Intake, and 16" CL Mesh Wheels.
I am not a rough driver. I 1/2 - 3/4 throttle the car in 1st & shift between 3,000 - 4,000 rpm into the next gear.
The issue I am having is a shutter felt though the car in 2nd gear, around 2,250 - 3,000 rpm, on 1/2 - 3/4 throttle. It feels like something is skipping/slipping, and is worse when the A/C is on. Occasionally, this will also occur in 3rd gear under the same conditions as well.
I recently changed the passenger side axle, both driver and passenger Hub Assembly, Bearing Assembly, Rotors, Pads, and had an alignment. I've checked and rechecked everything to see if anything was loose, and there was nothing.
My only assumption at this point, is the car is just under powered and is struggling to generate enough power to get moving.
Any insight and/or suggestions would be greatly appriciated.
Thanks!
Old Sep 5, 2008 | 05:59 AM
dtapia's Avatar
Default Re: Engine & Steering Shutter Issue (NGUSPEED)
sounds like a inner cv joint. you can grab the inner joint and hold the cup and see if it has play either side to side or up and down.
Old Sep 5, 2008 | 07:20 AM
NGUSPEED's Avatar
Default Re: Engine & Steering Shutter Issue (dtapia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtapia &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a inner cv joint. you can grab the inner joint and hold the cup and see if it has play either side to side or up and down.</TD></TR></TABLE>
The inner joint, meaning the side attached to the drive train?
If it has shaft play, then it's a bad CV?
Old Sep 5, 2008 | 04:17 PM
dtapia's Avatar
yes if you hold the inner cv joint and try and move it in a turn motion if their is play it will move
Old Sep 16, 2008 | 05:10 AM
NGUSPEED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dtapia &raquo;</TD></TR><TR><TD CLASS="quote">yes if you hold the inner cv joint and try and move it in a turn motion if their is play it will move </TD></TR></TABLE>
So do I have to detach it from the drivetrain or leave it in?
See if it moves up & down, left & right? right?
marcosleandros
Honda Civic (2001 - 2005)
10
Aug 18, 2010 10:46 AM
Samuels
Aug 15, 2009 05:57 PM
viet_tec
Aug 20, 2008 05:40 PM
medside
Jul 31, 2006 07:11 AM
