problem with corner lights
Old Sep 7, 2008 | 09:56 AM
Splitf22's Avatar
Default problem with corner lights
The right corner light stays on and in the interior has an anoying beep sound every 2 or 3 minutes. The other problem is that all the tail and stop lamps works fine, but in the dash it indicates a stop light failure, help please.
PD the car is Accord EX 1994.
Old Sep 7, 2008 | 07:54 PM
jwicecold's Avatar
Its most likely a sensor problem/failure or electrical malfunction.
Old Sep 7, 2008 | 08:13 PM
TheMuffinMan's Avatar
He knows where you live!
Brake fluid possibly on the one.
Annoying Beep? Do you have a door open?
Old Sep 8, 2008 | 05:30 PM
Splitf22's Avatar
I read a few months ago on other forum that was a ground problem, but i don't find the info again. It is rare and I know that all the problems the car has is in one place because they start at the same time and I verify the service manual and they share ground connections at some points. I'll try to reach those grounds on the weekend re-check them.
Some of the problem it has right now are
Defogger not working
Wiper when the washer is in use not working
right corner light stays on all the time
4 time beep under dash every 2 or 3 minutes
cwpage
Oct 24, 2016 11:16 AM
robin-m
Honda CR-V & Element
Jun 19, 2014 06:25 PM
Weisel612
Jul 17, 2013 03:12 PM
spark66
Jan 21, 2008 02:43 PM
