Help!!!
Old Jan 16, 2009 | 03:59 PM
charliebcdaccord's Avatar
Default Help!!!
Please help i can't figure out why my car isn't running right.
SYMPTOMS:
rough high idle
as soon i hit the throttle it bogs out, it shuts down if i hold it open it's like it is choking out
check engine light.
help please
Old Jan 16, 2009 | 04:10 PM
redbull-1's Avatar
Default Re: Help!!!
Jump the service connector and try to read the trouble code. Then post the code.
http://techauto.awardspace.com/dtc.html
Also tell us your year, trim level (DX, LX, EX), # of cylinders, etc.
Old Jan 17, 2009 | 09:22 AM
Aim m3 lat3r's Avatar
Default Re: Help!!!
throttle position sensor, plugs. ect...
Old Jan 17, 2009 | 09:42 AM
P_Adams's Avatar
Default Re: Help!!!
SYMPTOMS:
rough high idle
check engine light.
help please
Recover and Publish your DTC.
Sounds like a possible issue with a vacuum leak, possibly involving the MAP sensor (Manifold Absolute Pressure).
The vacuum leak could be responcible for the high idle.
Could you PLEASE take a moment and devulge what year and sub model this Accord is?
P
Old Jan 17, 2009 | 11:57 AM
GhostAccord's Avatar
Default Re: Help!!!
x2 Check Engine Light will give you a really good start..... retrieve the code and someone ^^ P_Adams or someone else will be able to help you rather than guess at the cause of your problem.
Old Jan 17, 2009 | 12:51 PM
YeuEmMaiMai's Avatar
Default Re: Help!!!
so did someone mention get the trouble codes yet?
x2 on vaccum leak
Old Jan 17, 2009 | 02:51 PM
Default Re: Help!!!
my car is a 95 ex coupe with an h22 swap i just finished the swap and i am stuck
Old Jan 17, 2009 | 07:34 PM
masterkill455's Avatar
Default Re: Help!!!
check your vac hose diagram in the manual and since you just installed this engine make sure all the hoses are hooked up and in the right place and be sure the hoses are good (not cracked pinched hard or spongy) and then you will definately need the codes
leclerc-123
May 23, 2019 05:09 PM
Llovero95
Jan 31, 2016 06:31 PM
StrokeDC2
Sep 20, 2012 05:50 PM
I Like Hondas
Jun 11, 2006 05:35 PM
hybridmike
Sep 16, 2001 07:48 PM
