1998 accord timing and balance shaft setting.
I'm performing a simple oil leak fix from the rear (exhaust side balance shaft) do they have to be phased into timing ? How is it done?
I'm asking this because Mitsubishi's have a similar setup.
The vehicle is a 98 EX F23 VTEC.
Re: 1998 accord timing and balance shaft setting.
are you replacing the front oil seal on the balance shaft?..If so yes it has to be phased into timing, although it is a simple task to do so. All you have to do is remove the 12mm bolt from the block near the oil filter, stick a screwdriver into the hole and rotate the balance shaft sprocket until the screwdriver "clicks" into place and install the belt. reinstall the bolt and you are good to go
are you replacing the front oil seal on the balance shaft?..If so yes it has to be phased into timing, although it is a simple task to do so. All you have to do is remove the 12mm bolt from the block near the oil filter, stick a screwdriver into the hole and rotate the balance shaft sprocket until the srewdriver "clicks" into place and install the belt. reinstall the bolt and you are good to go
the method you listed will only work if the balance shaft belt is still on the motor and assuming that the alignment was correct to begin with. Otherwise in a situation where the belt is already off the sprocket and then the sprocket was turned accidentaly you would have to follow my procedure in order to realign it properly
That's exactly what I'm saying, that you have to rotate the crankshaft until it lines up the timing marks (assuming the timing belt is still on), and then check to make sure the balance shaft belt marks are lined up, and then stick the screwdriver in place. The screwdriver fits into an indentation and keeps the rear balance shaft sprocket from turning. The front sprocket is fairly easy to align because it has the huge notch in it.
No. all f series and h series motors have 2 seperate belts, 1 is the main timing belt and the other is the balance shaft belt. The actual procedure goes like this. Rotate the crankshaft until the crankshaft pulley timing marks line up with the markings on the block and also when the camshaft sprocket reads "up". now you can remove the crank pulley and remove the main timing belt.
OP, do you understand the correct procedure? If all belts are off, here it is step by step.
1)Install timing belt and correctly set timing with #1 at TDC
2)Align rear balance shaft sprocket by removing set screw (bolt on back of engine), inserting a screwdriver or other object, and rotate sprocket until screwdriver "clicks" into place.
3)Align front balance shaft sprocket by lining the indentation on the shaft with the arrow/marker on the block.
4)Insert balance shaft belt making sure that when the slack takes up, the marks are still aligned.
5)Remove screwdriver and reinstall set screw.
6)Make sure the belt is correctly tensioned.
If the timing belt has stayed on throughout, just modify step one and only rotate the engine so that #1 is at TDC.
i was a moron and kept playing with my rear balancer and just aligned both marks pointing to the front and put everything back on
the whole car vibrated a lot and when revved sounded like a pissed off sewing machine
that process is simple enough thanks 4671 hybrid, i'll try it later
hooray i get to try again
not gonna drive the car all vibratey
masospaghetti
09-22-2014 05:31 AM
