Question on building engine
Old Jan 31, 2003 | 04:46 PM
RotiEatter's Avatar
Ditto
Default Question on building engine
I have a question for you guys this is directed to anyone who knows a good bit about cars by the way I have a 1997 Honda Accord Auto I'm doing a H22a Manual conversion I'm planning on building the engine and turbo charging it with a T60-1 @ 20psi it my question is What should I get done to my engine for this application?
Im thinking of just porting and polishing it
Boring it out But I don't know what to?
and sleeves and of course low compresion internals
anyone have any suggestions or experiance with this
anything would be greatly appreciated
Thanks
Vic
Old Jan 31, 2003 | 06:45 PM
Maybomb119's Avatar
Default Re: Question on building engine (RotiEatter)
Well so far you seem pretty correct on what you are doing, Resleeving will probably be a neccesity because the stock sleeves are definately not strong enough to handle that kind of boost. I love the idea of the port and polish, but boring it out is not neccesary. I would definatly put my money towards internals, especially if you want to run that high on boost. anyways thats just my $0.02, and good luck on the build.
Old Feb 2, 2003 | 05:40 PM
mrnicolas's Avatar
Default Re: Question on building engine (Maybomb119)
I would definately spend your money on building the internals very well. Make sure to take it to a reputable shop to have any machining done. Try to get it on a flow bench. Resleaving is a must to run that kind of boost. Now if you were running a f22b1.............................
reddragoncivic
Apr 5, 2019 09:47 PM
Maluko
May 5, 2009 05:10 AM
scheistermeister
Jan 12, 2006 08:47 AM
Corruption
Apr 18, 2005 03:12 PM
