idle problem ???
Old Jan 29, 2003 | 10:41 AM
AcCoRdStReEtRaCeR's Avatar
Default idle problem ???
hey i have 91 accord (f22a1) . I put in a 92 motor (f22a6) i got everything connected. when i got it started the idle stayes at 2300k then startes to jump around . if you give it alil gas or when it startes to warm up. the idle startes to jump . what sensors or what can cuase this .. please help thank you so much ????
Old Jan 29, 2003 | 11:01 AM
jweller's Avatar
Default Re: idle problem ??? (AcCoRdStReEtRaCeR)
Check engine light on?
Old Jan 29, 2003 | 11:06 AM
Kwisatz Haderach's Avatar
Not sure, but it sounds like a computer problem. Did you hook the f22a6 ecu up right?
Old Jan 29, 2003 | 08:02 PM
Default Re: idle problem ??? (Slamd4GAccrd)
yes the check engine light was on . No, i still have my lx ecu should i use a ex ecu i heard they are the same. ???????
Old Jan 30, 2003 | 07:07 AM
I ran my ecu for codes. it was a code 7 (tps). could tps sensor cause this problem . if not what else . I need your help ... please ?????
Old Jan 30, 2003 | 07:17 PM
need help ?
Old Jan 30, 2003 | 07:53 PM
jweller's Avatar
yes a bad TPS could cause this. Id reccomend hooking a multimeter up to your TPS and seing what kind of voltage reading you get. if it's fluctuating, or out of it's normal operating range than it's gone bad and you need a new one. unfortuneatly Hoinda only sells the TPS along with the rest of the throttle body. you can get one off a car in a junkyard though. but each tps is tuned to a specific throttle body, so expect it to be a bit off.
Old Jan 30, 2003 | 07:58 PM
Default Re: idle problem ??? (jweller)
is the throttle body of a lx the same as a ex ?????
Old Jan 30, 2003 | 08:08 PM
jweller's Avatar
I'm not sure for those years
alextech
12
Nov 24, 2018 06:29 AM
drzfamas718
20
May 5, 2011 06:48 PM
got00rice
Dec 30, 2009 12:16 PM
Catman316
Mar 21, 2005 07:51 PM
dvcart106
Aug 6, 2003 08:41 AM
