suspension problems
Old Jan 27, 2003 | 10:40 AM
turbocrazy's Avatar
Default suspension problems
lately i been driving in my car and there seem to be a problem with my suspension or something related, but not too sure what it is. the probelm is this whenever i drive over a bump or coarse road it seem to make a shreaking noise in the front driver side. can someone help?????
Old Jan 27, 2003 | 10:55 AM
urbanlegend21's Avatar
New User
Default Re: suspension problems (turbocrazy)
take a pretty good look at that side suspension and look for metal to metal contact
also could you describe it a little better
Old Jan 27, 2003 | 11:10 AM
iam7head's Avatar
Default Re: suspension problems (urbanlegend21)
stock set up? or aftermarket?
any special wears on tires?
high mileage vehicle?
[Modified by iam7head, 8:13 PM 1/27/2003]
Old Jan 27, 2003 | 12:15 PM
amroger2's Avatar
Default Re: suspension problems (iam7head)
I am also having this problem. 2002 Accord V6, no modifications to the vehicle. The car has 19k, amassed over 13 months. I've been to the dealership twice already, and they've failed to fix the problem. They 1) replaced the strut, and 2) added lubricant to the area.
For me, the squeak occurs on the front passenger side, and is most noticeable going over bumps in the road, but i also hear it (quieter) when just turning the wheel or braking. You can put pressure on the car's front right wheel and hear the noise in both the downward and upward motions. It's a fairly low-pitched noise. It seems to be louder after longer trips, but that could be my imagination.
The original poster can comment on whether this matches his problem, but it sounds like the same thing. Any suggestions to try before i take this back to the dealership a THIRD time?
Old Jan 27, 2003 | 07:33 PM
Hondaaccordvtec's Avatar
Default Re: suspension problems (amroger2)
Sounds like a squeeking bushing? Either upper control arm or lower control arm.
Old Jan 27, 2003 | 07:41 PM
briq4's Avatar
Default Re: suspension problems (Hondaaccordvtec)
could be sway bar bushings need some lube? Just a thought.
Old Jan 27, 2003 | 07:46 PM
greensleeper's Avatar
it's nothing. turn up the radio, drive your car, and enjoy it.
Octanum
Feb 28, 2012 12:14 PM
5Point7Liter
Suspension & Brakes
Mar 17, 2009 10:54 AM
SiR99
Jul 30, 2006 01:39 PM
Sardawg
Dec 12, 2005 01:00 PM
