install help
Old Jan 23, 2003 | 08:07 PM
tbezel's Avatar
Default install help
there's no response in the Audio section so i'm posting here sorri,
is there a website or something that will provide instructions on what I need to take apart to run my wires thru. like where from the battery and into the car..and under the panels and into the trunk etc..or if someone can just briefly explain it here would be nice too..i see installdr.com but that only shows the deck install. it is for a 2000 accord cpe. thanx
[Modified by tbezel, 5:08 AM 1/24/2003]
[Modified by tbezel, 5:11 AM 1/24/2003]
Old Jan 23, 2003 | 08:09 PM
iam7head's Avatar
Default Re: install help (tbezel)
english..by any chance you speak it?
Old Jan 23, 2003 | 08:17 PM
Accord94DX's Avatar
run a 0 gauge wire from the postive battery terminal to your dogs *******. if it barks you need to run it from the positive terminal, if it yelps, run it from the negative terminal.
Old Jan 23, 2003 | 08:23 PM
ratherbewalking's Avatar
what IS your question? in english
Old Jan 23, 2003 | 08:33 PM
.Noah Fecks's Avatar
look for a little rubber grommet, you putz. when you find it, take it out, or cut a hole in it.
Old Jan 23, 2003 | 08:53 PM
Accord94DX's Avatar
aye **** yall *****z, talkin **** behind your computers, cant even give lil help with respect
i think we just got some e-caps busted at our domes.
Old Jan 23, 2003 | 09:29 PM
iam7head's Avatar
Default Re: install help (Accord94DX)
LOL ever heard of icy hot stunna?
yeah..you sound just like them..
Old Jan 23, 2003 | 11:40 PM
XxDemonxX's Avatar
ROFL....try ur *** if neither of those works
Old Jan 24, 2003 | 03:34 AM
urbanlegend21's Avatar
New User
Default Re: install help (XxDemonxX)
you guys need to check yourselves, I am the biggest dick on here but he did say he couldn't get a response from anyone in the Audio section, his english is a little cluttered but let him try to clean up in his next post before bashing him
with that said................
there's a rubber grommet on your firewall behind the glove compartment where a wirring harness runs through, cut a small hole in that and run your wire through
I would suggest pulling up the passengers side carpet and running your wires under it right next to the door jam, this will require removing the front seat and rear seat, which is not really that hard
Old Jan 24, 2003 | 05:10 AM
jweller's Avatar
Default Re: install help (urbanlegend21)
what he said except one thing you might want to consider.
Power wires create interferance and noise with speaker wires. so you shouldn't run them next to each other, even with high quality, shielded cables. On my car the main wire harness runs down the drivers side, so ideally, you would run all your power down that side and your speaker wire and RCAs down the other side.
Having said that, You've got to have a super competitive SQ setup before this even begins to make any difference at all. take it FWIW
Old Jan 24, 2003 | 05:20 AM
Nick M's Avatar
Default Re: install help (jweller)
Post in english and give us some respect and we will give you all the respect you want.
Do that again and your account will magically disappear.
spaceman00
14
Apr 4, 2006 08:53 AM
CooBlueDAB
Audio / Security / Video
Dec 2, 2004 01:21 PM
Halo
Jul 22, 2003 02:55 PM
fstylin
Aug 17, 2002 03:24 PM
