Problem with back tire
Old Jan 27, 2003 | 07:10 PM
ajd2004's Avatar
Default back tire squeaking...help!
hey guys, I think something's wrong with one of my tires or the rear supsension or something, because there's this sort of squeaky sound, kind of a grinding sound, that i hear whenever the car moves. it's the rear tire on the driver's side. any help would be apreciated. thanx.
-alex
[Modified by ajd2004, 4:15 AM 1/28/2003]
Old Jan 27, 2003 | 07:23 PM
Hondaaccordvtec's Avatar
Default Re: back tire squeaking...help! (ajd2004)
Stuck E-Brake?
Old Jan 27, 2003 | 07:27 PM
ajd2004's Avatar
Default Re: back tire squeaking...help! (Hondaaccordvtec)
what is that? also, i think it looked like some oil or some black liquid resembling oil was leaking around the independent rear suspension. is it safe to drive the car short distances?
Old Jan 27, 2003 | 07:29 PM
If you see liquid of somesort - mostly likely you have a blown strut.
Old Jan 27, 2003 | 07:36 PM
ajd2004's Avatar
how does that happen, and is it expensive to fix? this guy fixed my car up and put in a new engine with only 40,000 miles on it, and he fixed a whole bunch of stuff. i don't know if he replaced the struts, but he replaced some stuff to do with the rear suspension.
Old Jan 27, 2003 | 07:37 PM
Are you running a stock suspension or have you dropped it w/ aftermarket struts?
Old Jan 27, 2003 | 07:38 PM
Also What Year accord?
Old Jan 27, 2003 | 08:08 PM
ajd2004's Avatar
sorry, 89 accord, the struts aren't anything special, not for racing or anything, or modified, just normal accord struts. thanx for all your help. do you think it's ok for me to drive to school tomarrow before i take it somewhere?
Old Jan 27, 2003 | 08:15 PM
greensleeper's Avatar
well squeaking and grinding aren't exactly the same thing.
grinding... wheel bearing?
but if there's an obvious dark liquid (touch it. is it petroleum base? oily?) then blown strut it is.
Old Jan 27, 2003 | 08:42 PM
Desslok's Avatar
Default Re: back tire squeaking...help! (greensleeper)
Is it by the brakes at all? Could be brake cylinder leak.
m1am1sf1n3st
Jan 27, 2010 01:48 PM
mr. robot-o
Aug 25, 2008 02:04 PM
Built B16A
Honda Motorcycles
Jul 31, 2008 08:49 AM
XoUnKoWnXo
Aug 23, 2004 07:49 PM
0ptimus prime
Feb 19, 2004 03:12 PM
