Check Engine Light?
Old Jan 30, 2003 | 12:49 PM
TJP_AccordV6's Avatar
Default Check Engine Light?
I don't understand y my check engine light is on after i reseted my ECU and diconnect my battery?
Anyone else is having this problem i dunno it might be the electrical or something else.
Old Jan 30, 2003 | 12:50 PM
YeuEmMaiMai's Avatar
Default Re: Check Engine Light? (SiRAccord)
did you accidently loosen something up?
Old Jan 30, 2003 | 01:08 PM
JimBlake's Avatar
If you reset your ECU, then its still picking up a fault. If the original fault was bogus, or it was just momentary, then resetting your ECU would make it go away. Since it came back, that means the problem is still there. You gotta read what the fault code is.
Some places like AutoZone will read them for you for free... If they tell you something that doesn't make sense, post back & tell us.
Old Jan 30, 2003 | 01:15 PM
Default Re: Check Engine Light? (JimBlake)
You think it might be the Catalyic Converter. Because i Hollowed it out.
[Modified by SiRAccord, 5:21 PM 1/30/2003]
Old Jan 30, 2003 | 02:04 PM
niedejb's Avatar
Yes. That would cause a CEL.
Old Jan 30, 2003 | 05:08 PM
Does the Check Engine light restrict or limit the power of my car??
Old Jan 30, 2003 | 05:49 PM
iam7head's Avatar
here the situation for my car...2002 accord coupe
when i got my hi flow cat, there's no slot for the o2 plug,
the cel is on of course and I am running rich.
harm performance and gas mileage
the solution:: bypass the secondary o2 sensor(aka cat. converter sensor)
and it will go away(cel).
I did it with some simply resistors and capacitor.(thx to Boosted cl guy )
Also, if you are lazy and rich go grab a o2 sensor simulator for about 100 buckx
[Modified by iam7head, 2:50 AM 1/31/2003]
Old Jan 30, 2003 | 06:08 PM
niedejb's Avatar
Technically no.
You wont know if anything else is wrong if you drive around with it on. I.e. you get a another code.
There are codes that will put your car in limp mode and you'll have no way of knowing when it happens.
Old Jan 30, 2003 | 08:44 PM
Old Skool's Avatar
Default Re: Check Engine Light? (niedejb)
what did you did you do to the car before you reset the ecu? header? intake manifold? throttle body?....
Old Jan 31, 2003 | 04:06 AM
Stew Pidasso's Avatar
FYI , a hollowed out converter will cuase a lot of exhaust turbulence. A high flow cat or testpipe would be much better for you.
sublimenerd
Oct 19, 2006 09:11 PM
Project_EK
Aug 13, 2005 04:08 PM
integra_type-r
Dec 14, 2004 04:04 PM
EKtypeRhaTcH
May 2, 2003 08:03 PM
NastyGSR
Oct 8, 2002 11:41 PM
