automatic Transmission problem,
Old Nov 11, 2008 | 08:34 PM
ERT1967's Avatar
Default automatic Transmission problem,
I have a 1990 Accord; it goes hard into 2nd gear and sometimes jumps up 1000 rpms right before it goes into 3rd. It seems to change well when I change fluid but I did that 4 months ago.
Old Nov 12, 2008 | 02:46 AM
P_Adams's Avatar
Default Re: automatic Transmission problem, (ERT1967)
Before you go off spending all sorts of money, try cleaning the Shift Solenoid Screens (6 and 8) located under the Shift Solenoids. They occasionally clog from debris and you get stuff like this.
Refer Illustration:
P
Old Nov 17, 2008 | 09:31 PM
ERT1967's Avatar
Thank you very much, will do.
Old Nov 18, 2008 | 11:29 AM
whalenbrinton's Avatar
let me know if that worked for you, i have the same problem
Old Nov 24, 2008 | 09:40 AM
ERT1967's Avatar
The screens were clean, so it look like I need to replace the tranmission. It cant hurt to check; just remove the fan and clean the area. Make sure the area is clean before your put the Shift Solenoids back or it will leak.
recka808
Mar 15, 2012 08:55 AM
gotofbi
May 30, 2011 06:17 PM
sohc prelude
Feb 26, 2006 07:26 PM
enabi
Oct 1, 2005 10:22 PM
JDM4DRACCORD
May 23, 2005 09:03 AM
