VTEC PROBLEM!!
Old Oct 29, 2008 | 03:44 PM
919DumpedCD5's Avatar
Default VTEC PROBLEM!!
I HAVE AN H22 SWAPPED IN MY 95 ACCORD. I FEEL THE VTEC KICKING IN ABOUT 5000 RPMS AND ITS BOGGING OUT ABOUT 6500 RPMS. I HAVE A CEL CODE 12, EGR VALVE LIFT SENSOR AND CODE 22, VTEC PRESSURE SWITCH. COULD THOSE CAUSE THE PROBLEM. CAN ANYBODY HELP?? THANKS.
Old Oct 29, 2008 | 04:30 PM
sixgunsound's Avatar
Default Re: VTEC PROBLEM!! (919DumpedCD5)
If you have a CEL then VTEC will not work.
And turn off the caps lock for god sake.
Old Oct 29, 2008 | 05:25 PM
FunnyVictor86's Avatar
so with any CEL it wont engage? i dont even remember if mine ever kicked in when i had a CEL ... i cant even check anymore because my vtec engages no mater what because of my VAFC ... anyway yes fix those ... clear the CEL's ... and you will be smiling once again
Old Oct 29, 2008 | 05:51 PM
thanks!! my bad for the caps. really not use to people getting mad over caps. i know its means yelling on the internet. but i dont mean anything by. it. its just how i type or write, i think it looks better like that. but thanks ill get those fix.
Old Oct 29, 2008 | 06:21 PM
Default Re: (FunnyVictor86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FunnyVictor86 &raquo;</TD></TR><TR><TD CLASS="quote">so with any CEL it wont engage? </TD></TR></TABLE>
Nope, the ECU wont let it engage as a precautionary measure.
Old Oct 29, 2008 | 07:01 PM
kevodean's Avatar
my vtec oil pressure switch was broke off, check to see if yours is in tact...you can look it up on majestic honda and get it there or advance auto parts will order it for you and itll cost $50...oh and they will think its a part that costs $7 bc there [freak]ing idiots...but trust me it costs $50 and its called an oil pressure swith assembly for vtec....
good luck man, its really easy to change btw and once its done....HONDAAAVTEC!!!!
Old Oct 30, 2008 | 11:32 PM
VtEcNcHeEsE's Avatar
Check ur plugs doode
Old Oct 31, 2008 | 02:28 AM
GhostAccord's Avatar
Default Re: (sixgunsound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixgunsound &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, the ECU wont let it engage as a precautionary measure.</TD></TR></TABLE>
Where did you read/learn that?
Just because the CEL is on doesn't mean that it's in back-up mode. (aka limp mode)
I would have to say his VTEC is not working properly because there is a problem with VTEC itself. That would be my guess as he is throwing a code 22. He didn't say his VTEC wasn't engaging. He said it would bog down as his RPMs went higher. Lack of oil pressure maybe?????
Low oil pressure or a dirty oil screen in the pressure switch could be why this problem is occurring. Have you changed your oil lately?
Before you go out and buy a new pressure switch check your oil. Make sure it is the proper weight, that it is clean and up to its proper operating level. Once you have checked that remove the VTEC solenoid/pressure switch and clean the screen that fits between the switch and the head if it needs cleaning.
After that there are some electrical tests that you can run. It would help if you have a manual that shows the testing procedures. There are a few different ways of obtaining a manual.
Old Oct 31, 2008 | 03:20 AM
Default Re: (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">
I dont remember where I came across that, I'm pretty sure I read it here. I'm not saying hes in limp mode, but it was my understanding that as long as you have a CEL then VTEC wont engage.
Old Oct 31, 2008 | 04:03 AM
hahakenny's Avatar
I have a H22 swap in my 95 accord as well and an intermittant EGR CEL code. When the light's off, Vtec hits great... when light's on, Vtec hits but it's a little more boggy as well.
I too have a VAFC so I'm thinking the VAFC helps.
But is it correct that if the Pressure Switch light is on, that's the thing that disables Vtec?
Old Oct 31, 2008 | 05:02 AM
Default Re: (hahakenny)
I'm not 100% that Code 22 actually disables VTEC. I do know that it certainly means that there is something wrong with your VTEC pressure switch. Be it electrical, bad wiring or mechanical low oil pressure.
civictype-r
Mar 15, 2006 04:19 PM
four o two
Dec 22, 2005 11:47 AM
Flux
Jun 7, 2004 08:50 PM
AtomicEG
Sep 3, 2003 05:39 PM
Rhetoric
Jan 2, 2002 01:10 AM
