speedo problem
Old Nov 6, 2008 | 12:33 PM
sneakerfern's Avatar
Default speedo problem
well i purchased a 90 accord ex automatic. stock ,the problem that i'm having is that the odometer isnt working, the rpm gauge is fine, i replaced the speedo sensor and it didnt fix it, im told that the ecu might be the problem help!!!!!!!!!!!!!!!!!!!
Old Nov 6, 2008 | 12:59 PM
P_Adams's Avatar
Default Re: speedo problem (sneakerfern)
It's either dash wiring (someone cut something they shouldn't) or the cluster itself.
If the ECM were malfunctioning, The "Check Engine" lamp would be lit.
If it had been the VSS (Vehicle speed sensor), I've seen both the D4 and the CEL lamp come on.
Cluster failures are not uncommon.
P
Old Nov 6, 2008 | 01:16 PM
Default Re: speedo problem (P_Adams)
cel isnt on.... so the cluster maybe?????? thanks btw
Old Nov 6, 2008 | 02:06 PM
TheMuffinMan's Avatar
He knows where you live!
don't search about cluster issues, you will get no help
Old Nov 6, 2008 | 03:41 PM
P_Adams's Avatar
More than likely.
You can sometimes find a replacement cluster thru several venues
1) Your local auto parts recycler.
2) Ebay
I know of no repair services (sorry)
P
mikej94civex
May 25, 2010 05:09 PM
EJ8-Yao
Engine Management and Tuning
Apr 21, 2009 05:28 PM
burgandybeast
Nov 2, 2007 02:30 PM
confusion
May 13, 2007 02:22 AM
honda25
Feb 5, 2003 05:08 AM
