vtec controller
Old Nov 5, 2008 | 04:48 PM
96accordexproject's Avatar
Default vtec controller
will it get me any more power or make my f22vtec any faster?
Old Nov 5, 2008 | 04:50 PM
TheMuffinMan's Avatar
He knows where you live!
Not really.
Old Nov 6, 2008 | 10:48 AM
FunnyVictor86's Avatar
it wont really make a difference on a stock eng. its nice being able to drop your vtec engagement point ... personally it made my vtec hit alot harder ... im not stock yet im not built either but maybe thats just me?
Old Nov 6, 2008 | 10:50 AM
pimpdd101's Avatar
Default Re: vtec controller (96accordexproject)
nada!
Old Nov 6, 2008 | 07:17 PM
02 accord's Avatar
Default Re: (FunnyVictor86)
What did you drop your engagement point to?
Old Nov 6, 2008 | 07:34 PM
Default Re: (02 accord)
ive dropped it down to 3500 just to play with it but i keep it at 4200 ... gotta let those non vtec lobes do their job at low rpms you know ... although i never payed attention to my engagement point before my vafc ... what is it normally? i dont wanna drop it too low nor set it too high ... advice plz
Old Nov 6, 2008 | 07:38 PM
02 accord's Avatar
Mine goes on at 2300. I thought that you dropped it below that.
I made a vtec light (for diagnosis) when I did my manual swap to see if I had vtec or not. Then I rigged up the auto ecu to read that I'm always going 35 mph, and now I can launch in vtec at anything above 2300 rpm. The cluster reads correctly though.
Old Nov 6, 2008 | 07:42 PM
geez and i thought i was setting it low at 3500 lol ... what performance upgrades do you have ... i would image you'd bog setting it at 2300rpm ...
Old Nov 6, 2008 | 07:46 PM
02 accord's Avatar
The only upgrades I have is a stock CAI (aka no resonator), a manual swap, and a 20mm rear sway bar. Everything else is stock, including the auto ECU. The stock engagement point is as low as 2300 (it goes on at 2300 every time under acceleration). When cruising, it will stay off up to 3500ish (85-90 mph). After that speed, every time I even touch the gas to hold my speed going up a slight incline, vtec kicks in.
Old Nov 6, 2008 | 07:52 PM
i have:
aem cai
megan header
stock exhaust =/
xact prolite flywheel
i havent really experimented with my vafc ... what would you recommend setting my engagement point
Old Nov 6, 2008 | 07:57 PM
02 accord's Avatar
Try setting it to 2300. I drove without vtec for a while, and it was a pain in the ***. No power at all. So I'm pretty sure that's how it feels when you don't have vtec until 3500+. And obviously, when it kicks in then, you'll feel it.
Edit: forgot to add that I have an Exedy stage 1 clutch. Tons of fun to drive.
Modified by 02 accord at 12:05 AM 11/7/2008
Old Nov 6, 2008 | 08:06 PM
What?!~
2300? Wayyyyyy too low
Old Nov 6, 2008 | 08:07 PM
02 accord's Avatar
Default Re: (TheMuffinMan)
Stock is 2300. You're saying that the engineers at Honda set it way too low?
Old Nov 6, 2008 | 08:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">Stock is 2300. You're saying that the engineers at Honda set it way too low?</TD></TR></TABLE>
Stock is a floating point starting at 2300, doesn't always start then. Statically setting it there then becomes an issue as the other requirements aren't probably met - which is probably why you noted power loss.
http://www.hondahookup.com/info/vtec.php
*edit*
As a side note, the VTEC in my H22 is statically set at 4600 and I wouldn't go much lower than 3500 static on the F22
Old Nov 6, 2008 | 08:18 PM
02 accord's Avatar
Ah, now it makes sense. Didn't realize that the vafc always engages at that point (I'm a little out of it right now). In that case, 3500 sounds like a good starting point.
Old Nov 6, 2008 | 08:20 PM
Old Nov 7, 2008 | 04:55 PM
current settings are ...
rpm engagement:
low/hi: 3500
hi/low: 3200
throttle point:
hi: 50%
low:15%
sensor type:
pressure
in: 5
out: 5
vteclife
Jan 3, 2008 08:49 AM
pokmijn
Nov 24, 2007 07:28 PM
sasinorm01
Oct 7, 2004 12:08 PM
South Bay Surfer
11
Apr 24, 2003 10:34 AM
Sleeping
May 4, 2002 01:56 PM
