Electrical problem
Old Jan 9, 2004 | 07:50 AM
elevatethis's Avatar
Default Electrical problem
A friend of mine has a 92 accord ex and is having some electrical issues.
Starts up fine.
Headlights turn on
the rest of the lights do not, that includes corner lights, taillights, brake lights, dash lights, etc.
Stereo still works.
Alternator is working perfectly.
Battery has a low charge, but it wouldn't matter since the alternator runs everything once the engine turns over.
The fuses for all those other lights blow within about 3 seconds on turning them on.
its blown a 5, 15, and 20.
Relay issue? Short circut?
thanks
Old Jan 9, 2004 | 08:14 AM
.bagged's Avatar
Default Re: Electrical problem (elevatethis)
Sounds like a bad ground some where..
Old Jan 11, 2004 | 10:43 PM
Qfactor's Avatar
Default Re: Electrical problem (bagged93accord)
check for rats, they like to chew on wires and can cause shorts. specially if you live out on the country side.
Old Jan 12, 2004 | 09:49 AM
vtNaMeSe's Avatar
i had the same problem with my 94 accord you've tried 5, 10, and 20 already so try a 7.5 i think it should work
Old Jan 12, 2004 | 11:50 AM
Perfectionist's Avatar
Default Re: Electrical problem (vtNaMeSe)
Replace fuses with only the orginal size fuses. Do not go higher. You'll be melting your wiring harness soon if you do.
There is obviously a short directly to ground in the affected circuit. Best thing would be to find a wiring diagram and go from there.
Did this just suddenly occur, or did it happen after some type of 'install'?
Old Jan 12, 2004 | 12:42 PM
godslayer's Avatar
Default Re: Electrical problem (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> had the same problem with my 94 accord you've tried 5, 10, and 20 already so try a 7.5 i think it should work
That will do nothing for you since you already know you are already pulling more than 10A through that circuit. Hell, you are pulling more than 20A through that circuit so no need to see if maybe a magical 7.5A fuse will work.
Old Jan 12, 2004 | 01:36 PM
vtNaMeSe's Avatar
Default Re: Electrical problem (godslayer)
well i had the same problem n it works for me so it should work for him my friend had the same problem also n it works for him ... sucker for corn rolls!!!!
Old Jan 12, 2004 | 02:03 PM
RotaryBzzzz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtNaMeSe &raquo;</TD></TR><TR><TD CLASS="quote">... sucker for corn rolls!!!!</TD></TR></TABLE>
??? Am I missing something?
Old Jan 13, 2004 | 05:40 AM
forcedaccord95's Avatar
Default Re: Electrical problem (RotaryBzzzz)
take a multi meter and check for shorts with continuity. im sure it is a short some where. also check the head light ground under the hood, this sometimes causes problems. pull off the drivers "a" pillar and check the interior light wires, theses also short out in hondas alot!
Old Jan 13, 2004 | 05:48 AM
typertn's Avatar
i had the same problem when i installed my halo's, you have to wire the halo into the corner light, when i did it, the piece of electrical tape came off and whenever the wire would touch the inside metal of the fender it would blow the fuse, that would make my dash, rear lights, corner lights, and bumper lights not work. look for a raw wire either in the corner, tails, or bumper lights, im sure thats it. I think there is one fuse called small lights that governs all of those
Puro Zacatecas
Nov 27, 2008 05:33 PM
alwaysgetsalemon
Oct 6, 2008 01:47 PM
Redtail
May 14, 2004 10:11 AM
sbestman22
Mar 9, 2004 11:57 AM
