02 sensor
Old Jan 9, 2004 | 03:20 PM
knowtomorrow3001's Avatar
Default 02 sensor
I can get one at Autozone for $90 without a wiring harness. The one with the wiring harness is like $180. Can you use the old wiring harness on the old one and save $100. If you can how hard is it to put the old harness onto the new 02 sensor. Or should I get one from honda for like $250? Also what does wideband mean? Will I need an OBD1 or OBD2? Im suppossed to get an upstream OE 02 sensor?
Old Jan 9, 2004 | 07:26 PM
Nick H's Avatar
New User
Default Re: 02 sensor (knowtomorrow3001)
you should be able to find them for no more than $70 most places
Old Jan 10, 2004 | 06:24 AM
jwogen1's Avatar
Default Re: 02 sensor (Nick H)
are these realitively easy to install, and arent there front and rear o2 sensors? which one pertains to a fuel related issue? thanks
Old Jan 10, 2004 | 06:28 AM
The_Todd's Avatar
Farts in the shower
Default Re: 02 sensor (jwogen1)
If its a 90-95 it should be an OBDI (only 1 o2 sensor) and a 96 and up should be OBDII....that has 2 o2 sensors. I am not 100% on the years but OBDI's have only 1 o2 sensor and OBDII's have 2 o2's
Old Jan 10, 2004 | 06:38 AM
briq4's Avatar
Nick H - where are the places that have them for 70 bucks? I'm at 300,000 miles and it's the original sensor still getting around 27 MPG but who knows maybe it could be better with a new sensor, p.s. it's a 93 EX 5-speed.
Thanks!
Old Jan 10, 2004 | 08:49 AM
jwogen1's Avatar
Default Re: 02 sensor (VRDrvr)
you're right man! 96 and up are OBDII with two o2 sensors, thanks for the help. are these easy to change myself if its on the headers?
Old Jan 11, 2004 | 01:53 PM
LookingForVTEC's Avatar
just to let you know I had a O2 sensor go bad on me. I tried to replace mine with an autozone sensor but it still threw a code. So I had to replace it with a OE Honda sensor.
Old Jan 11, 2004 | 02:11 PM
97F22B2's Avatar
The one in the manifold is easiest, especially if you remove the amnifold for more leverage. The one in the cat is a PITA
Old Jan 11, 2004 | 02:42 PM
philadd's Avatar
Default Re: (97F22B2)
i bought a bosch o2 sensor from autozone for like 60 bucks... i've had no problems with it
Old Jan 11, 2004 | 08:43 PM
jwogen1's Avatar
Default Re: (philadd)
bosch o2 sensor hasnt had any problems or thrown any codes?
Old Jan 12, 2004 | 07:41 AM
Did u guys buy the one with or without the wiring harness there is like a 100$ difference. What is the one with the wiring harness better quality. Can you use the originally o2 sensor harness? I need one bad its also seeming to make my car run a little different. But I have not checked to see if is throwing any codes. Im just positive it needs replacing.
This one
http://www.partsamerica.com/Pa...Set=C
OR this one
Thanks to everyone who responded
asoRm
Jan 21, 2024 09:25 PM
zerodohc
Jan 10, 2013 12:41 PM
D21X
Apr 7, 2005 01:24 PM
beasly
Jul 9, 2004 08:34 PM
