light problem, need help
Old Jan 5, 2004 | 01:12 PM
Ideal's Avatar
Default turn signal problem ,need help
well my corner light wiring cables were severed in a small accident, so i hit up a junkyard and replaced them, they turn on just fine, everything is perfect, except, when i use my indicators, only my rear lights blink and they blink fast, i cant figure what to do next!
thanks!
Modified by Ideal at 2:27 PM 1/5/2004
Old Jan 5, 2004 | 04:12 PM
The_Todd's Avatar
Farts in the shower
Default Re: turn signal problem ,need help (Ideal)
It might be a bad socket....is your front bulb burnt out or is it working? If its not burned out I would say socket. Also check your fuses the ones for turn signals and make sure everything is kosher like the pickle.
Old Jan 5, 2004 | 04:29 PM
Ideal's Avatar
Default Re: turn signal problem ,need help (VRDrvr)
the bulb is working perfectly, not burned out whatsover, where do i check the fuses? i look in the box up by the passenger side but i didnt see anything regarding turn signals.
Old Jan 6, 2004 | 12:13 PM
The_Todd's Avatar
Farts in the shower
I will have to look at mine, but I swore there was one or maybe a relay that says headilghts/turn signals, check those and I will look at mine to cross reference, mine is a 4th gen though.....should be about the same. And how do you know the bulb is not burned out? I would be leaning towards a bad socket or bad wiring.
Old Jan 6, 2004 | 12:16 PM
.bagged's Avatar
check you ground block. each side of your car has a little box about the size of hot wheel that all the ground wires for your lights (example left block has bumper light, corner light, marker light) all going into one. check to see if all your wires are good there too..
Old Jan 6, 2004 | 12:19 PM
Ideal's Avatar
Default Re: turn signal problem ,need help (bagged93accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord &raquo;</TD></TR><TR><TD CLASS="quote">check you ground block. each side of your car has a little box about the size of hot wheel that all the ground wires for your lights (example left block has bumper light, corner light, marker light) all going into one. check to see if all your wires are good there too..</TD></TR></TABLE>
around what area of the sides?
Old Jan 6, 2004 | 12:21 PM
Ideal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">I will have to look at mine, but I swore there was one or maybe a relay that says headilghts/turn signals, check those and I will look at mine to cross reference, mine is a 4th gen though.....should be about the same. And how do you know the bulb is not burned out? I would be leaning towards a bad socket or bad wiring.</TD></TR></TABLE>
wouldnt the bulbs be burne dout when they dont work and have black coating all over them? I also have 2 new amber bulbs on each corner light. How would i tell if i had a bad socket?
Old Jan 6, 2004 | 12:25 PM
The_Todd's Avatar
Farts in the shower
I only have the far corner bulb in and it doesn't throw off the circuit....to test your sockets break out the voltmeter.....but as bagged93accord said check your grounds too.
Old Jan 6, 2004 | 12:27 PM
Ideal's Avatar
yeah,i mean if i had a bad socke,t would the light still turn on?
im thinking its gonna be a ground, i hope it isnt a pain to find though
Old Jan 6, 2004 | 12:30 PM
The_Todd's Avatar
Farts in the shower
No if you had a bad socket it wouldn't matter if the bulb was good, the socket supplies the volts needed to power the bulbs and also complete the circuit...honda did this thing to wear if a bulb went out or something broke the circuit it would blink at at least double the normal rate, I guess to get your attention. I would look near the body near the sockets for the ground...I think the corner grounds are near the battery and the p/s on the other side...check it out and lemme know.
Old Jan 6, 2004 | 12:32 PM
Ideal's Avatar
will do and who is that check in your avatar !?!?!?!
Old Jan 6, 2004 | 12:33 PM
The_Todd's Avatar
Farts in the shower
A lil some some I picked up
Old Jan 6, 2004 | 12:52 PM
Ideal's Avatar
thank god for wireless internet
are the ground blocks easily seen through the top of the car, or am i gonna have to jack this sucker up?
Old Jan 6, 2004 | 01:43 PM
Ideal's Avatar
here is what ive discovered so far, 1) it isnt the lighting relay, because if that was gone, none of my lights would work, 2) it isnt the fuse becuase the actual lights turn on, they just dont blink
so now im sure of 2 things, its either the bulbs or a bad grounding, which sux0rs!
DC4R27
Mar 23, 2007 10:09 PM
Metal Typhoon
Oct 17, 2006 05:14 PM
2.2L EH2
Oct 10, 2006 11:10 PM
JaiDM
Feb 12, 2003 01:22 PM
joblow
Nov 14, 2002 08:49 PM
