How hard is it to replace outer CV boot?
Old Jan 5, 2004 | 07:04 PM
Mason Dixon
Guest
Posts: n/a
Default How hard is it to replace outer CV boot?
Gotta 96 accord manual. OUter passenger side boot ripped. Is it hard to replace? anybody have any tips/suggestions. Thanx
Old Jan 6, 2004 | 02:54 AM
WuWarrior's Avatar
Default Re: How hard is it to replace outer CV boot? (Mason Dixon)
You should replace the complete axle, not just the boot. Who knows how much grease was lost and how damaged the CV is.
Old Jan 6, 2004 | 05:08 AM
Mason Dixon
Guest
Posts: n/a
i ripped the boot while replacing the tranny seal so it hasn't got any dirt or gunk in it. The joint is perfect. I'm just wondering if i need special tools to put on the boot straps? How hard is it to get the bootstraps on and off?
Old Jan 6, 2004 | 05:21 AM
JimBlake's Avatar
Default Re: (Mason Dixon)
There's a special tool to crimp those tight. Looks kinda like a pliers, but a pliers won't work. Maybe AutoZone has them for rent/borrow? But I've even used a pair of nylon wire-ties to replace each clamp, that worked, too.
Old Jan 6, 2004 | 05:25 AM
jweller's Avatar
Default Re: (JimBlake)
check out what kind of band you have on the boot. My helms manual shows 3 different types. so some you might be able to get with pliers, and others look like you might need a special tool for
Old Jan 6, 2004 | 08:54 AM
Dave Slater's Avatar
Default Re: (jweller)
I have been able to remove the old straps using a pair of dikes to grab the end and peel it up, but anyway you can get them off is ok.
The new boot should come with new straps that you put on by hand without special tools. Usually there are a couple tabs to bend down once it is installed. However I have had good luck with nylon cable ties also.
Go ahead, you can do it! Just take your time and enjoy having it done right.
later, slater
oldskoolDA6
Jul 9, 2009 11:39 AM
StreetRiot_DRE
14
Apr 10, 2008 03:46 AM
JesseBizz
Apr 3, 2008 08:37 PM
TeginRAGE
Jul 17, 2001 06:17 AM
xtrafastcivic
Jun 17, 2001 03:23 PM
