91 accord starting problems
i have a 91 accord and everytime i try to start it, it cranks but it wont start....after cranking it a couple of times then it starts but if i dont push on the gas pedal it turns off...i think i might have a fuel delivery problem...i changed the throttle body on it and it still has the same problem...can it be my injectors????? any help would be apreciated thanx....
Re: 91 accord starting problems (AccordJDM413)
does your check engine light come on everytime you go to start it. Keep an eye on that, its prolly your main relay goin bad, our cb7s do it all the time, when it gets hot the solder for the contacts melts and it doesn't get a good connection, and it won't kick on the fuel pump, so the car won't start it'll just crank and crank, til it wants to act right, or your fuel pump might be goin bad lol, Fuel pressure test might be good to do soon. Good luck mang Let us know what u find
K00lGuy
01-14-2016 10:49 AM
86RedFoxBodyGT
07-10-2012 04:21 PM
ChronicFrogs2004
11-20-2004 08:02 PM
91EXRMANUAL
10-07-2004 07:08 PM
