spark plug tubes....please help
can you remove the sparkplug tubes out of the head of a f22 sohc vtec engine?
the rubber boot's at the bottom of the spark plug wire got melted to the plugs and i can't take the plug out unless i can remove the spark plug tube then i have more room
H-T Order of Merit
Re: spark plug tubes....please help (CONTROLLED CONFUSION)
I'm going to assume you'll have to go through the procedure of replacing the lower spark plug tube seals to do that. I dont think the spark plug tubes can just be removed.
Re: spark plug tubes....please help (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">I'm going to assume you'll have to go through the procedure of replacing the lower spark plug tube seals to do that. I dont think the spark plug tubes can just be removed.</TD></TR></TABLE>
i didn't think so either.....after a failed attempt
thanks
thanks
