Solid CEL Light?
Old Nov 10, 2007 | 02:18 PM
cB7KiD's Avatar
Default Solid CEL Light?
i've got a 90 honda accord with a h22 swap...other day pulled into taco bell parking lot and car died...wouldnt start for nothing...once i got home i tryed see'ing what my CEL was for and it wouldnt flash it stayed solid..So it could be my ecu which its not cause i bought a bran new one and it did nothing..So could it possible be my main relay??
Old Dec 6, 2007 | 11:02 AM
cB7KiD's Avatar
Default Re: Solid CEL Light? (cB7KiD)
bump...anyone?
Old Dec 6, 2007 | 11:13 AM
GhostAccord's Avatar
If you know it's not your ECU for sure then it's time to start checking the power and ground wires going to and from the ECU. If you have a pin out for your particular ECU and a multimeter your well on your way to finding a bad ground or short. I'm pretty sure there are only 2 power and 2 ground pins to check. This is a good place to start if your sure it's not the ECU and you have a solid CEL.
Old Dec 6, 2007 | 12:18 PM
awdgsx96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cB7KiD &raquo;</TD></TR><TR><TD CLASS="quote">i've got a 90 honda accord with a h22 swap...other day pulled into taco bell parking lot and car died...wouldnt start for nothing...once i got home i tryed see'ing what my CEL was for and it wouldnt flash it stayed solid..So it could be my ecu which its not cause i bought a bran new one and it did nothing..So could it possible be my main relay??</TD></TR></TABLE>
I'm pretty sure it has to be the ECU, as a solid CEL indicates an ECU malfunction. As Ghost mentioned, there could be a wiring gremlin
Old Dec 6, 2007 | 06:35 PM
Default Re: Solid CEL Light? (GhostAccord)
Ok here are a few other thing to check when you have a solid CEL.
• Check the ECU 15A fuse under the hood. Replace if bad
• Check the No.2 Fuel Pump 15A fuse under the dash. Replace if bad
• If both fuses are good try Turning the ignition switch on (engine not running)
Then disconnect the connector of each of the following sensors one at a time checking to see if the CEL goes off.
- MAP
- TPS
- EGR valve lift sensor
• if the CEL light goes out when you disconnect one of the sensors replace that sensor.
• If the CEL remains on leave the sensors disconnected and turn off the ignition. Then test for continuity between body ground and D19 & D20 pins
• Is there continuity, if there is. repair the short to body ground wire between ECU (D19) and MAP or ECM (D20) and TPS
• If there is no continuity reconnect all of your sensors and turn your ignition on (engine not running)
• Measure voltage between body ground and teh following pins individually A26, B2
• Is there less than 1.0v
- if no rapair open in wire between ECM (A26, B2 pins) and Grd101
- if yes try a new ECU.
Old Dec 7, 2007 | 02:40 AM
awdgsx96's Avatar
That looks like really good info to have. Where did you find that from?
Old Dec 7, 2007 | 12:32 PM
Default Re: Solid CEL Light? (awdgsx96)
I had to use this test procedure once before when I was troubleshooting an ECU that I had chipped. I got this particular flow chart out of my Honda Motor Co. CD7-9 shop manual.
Track Beast
Dec 5, 2010 01:04 PM
hmtcrxsir
Sep 23, 2007 02:32 AM
RexB16
Jun 3, 2005 10:34 AM
ek4d00r
Apr 29, 2004 04:46 PM
BoostedH23a1
Mar 21, 2003 01:36 PM
