Engine knock question
Old Nov 12, 2007 | 11:46 AM
aries331's Avatar
Default Engine knock question
Engine knock, how can i tell if I have one, what does it sound like and when does it do it???
Old Nov 12, 2007 | 12:41 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: Engine knock question (aries331)
was your motor running fine abd then yiu started kearing a slight cluck or tinking that intensified in consistancy and tone could you feel a knocking hear it under the hood??????
Old Nov 12, 2007 | 04:49 PM
aries331's Avatar
Default Re: Engine knock question (I got the CD5 Jeebies!)
The engine runs fine, but I do hear a clucking sound from under the hoos, it only does it when I'm slowing down or taking off, most likely into second gear.
Old Nov 14, 2007 | 05:16 PM
with a rod knock your gonna hear the same noise at all rpms..not just in which gear your in.....what kind of sounds is it? can you upload a vid??
Old Nov 14, 2007 | 06:52 PM
SOHCMAN's Avatar
There is a chance it could be valve noise, I'm sure someone knows how to differentiate between valve noise and the knocks, pings, and other bad noises...
Also, the way you descried it, it could be a loose heat shield buzzing when you either take off or decelerate.
sohc
Old Nov 15, 2007 | 12:25 PM
aries331's Avatar
Default Re: Engine knock question (SOHCMAN)
I am hoping it's just something loose in the suspension, last week I took the car to honda for tranny fluid change and the service guy told me that my stabilizer bar bushings needed to be replaced, so it clould easily be something loose under the engine or something.
Old Nov 20, 2007 | 01:47 AM
honda671's Avatar
why don't you try out Seafoam?
http://members.nuvox.net/~on.r....html
Old Nov 20, 2007 | 03:51 AM
YeuEmMaiMai's Avatar
year make and model?
F22x is known for excessive cam journal wear on #2 cylinder that causes a clicking noise that sounds like rattling valvetrain.
you want to know if the engine is knocking? drive up a steep hill and you will definately know it.
Old Nov 20, 2007 | 04:18 AM
Tyte-S's Avatar
Default Re: Engine knock question (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote"> drive up a steep hill and you will definately know it.</TD></TR></TABLE>haha Not exactly scientific, but true. If you only hearing it in one gear, thne it's probably something else. Is this noise something your car has always made, or has just started to receently. Also Yr and model help.
Twistedframe
May 27, 2022 05:28 PM
landos2k
Honda S2000
Aug 14, 2015 12:42 PM
Big_Tee
16
Dec 11, 2013 04:06 AM
jhammond_82
Oct 16, 2009 10:53 AM
