Late 2005 Honda Pilot Brake Line Bleeding Problem
I am working on my Sister's late 2005 Honda Pilot. I have replaced the rear pads and rotors along with the master cylinder. I properly decompressed the rear calipers and I have bench bled the master cylinder. And there are no leaks anywhere. Now that has been said, I've been having problems bleeding all 4 lines. After an extensive battle I finally got 3 of the 4 lines to bleed. The last one I am having a problem with is the front right passenger side brake line. I have done everything correct and I am getting no fluid coming out. What else is there that I can do? Any Ideas?
Cool Cool Island Breezes. BOY-EE
Re: Late 2005 Honda Pilot Brake Line Bleeding Problem
What do you mean, "everything correct"?
Use a 1 man bleeder. Its easier to bleed brakes with the car running also.
Thanks for your input. It turned that the master cylinder was defective. Once replaced everything went well afterwards. So thanks again.
STN_Pat
03-20-2009 10:55 AM
