Suspension & Brakes Theory, alignment, spring rates....
ABS pick up, spec help needed
Old 05-26-2019, 06:39 PM
BongoBennie's Avatar
Default ABS pick up, spec help needed
Looking to swap a 2017 HRV rear axle onto a 2001 Insight. Insight has the older style ABS pickup with the 50 tooth sprocket visible on the hub similar to RSX style pickup. The HRV (that I haven't bought yet) appears to have the newer style where the sensor pokes into the hub and whatever wheel its reading is behind closed doors. Does anyone know if the ABS output on Honda car are all the same or did it evolve and I will need to convert? Thanks in advance.
BongoBennie is offline
Collsj
Honda CR-V & Element
06-20-2017 03:28 AM
nico91civic
11-12-2008 09:04 AM
kruption
04-29-2008 03:47 PM
fakemike
13
02-20-2005 04:16 PM
saber1
11-03-2004 07:53 AM
Quick Reply: ABS pick up, spec help needed
  • Ask a Question
Question Title:
Description:
