BenseBuilt OEM Brake Rotor Chart
Go Tigers!
I have created this chart that some of you may find helpful. I am attaching a screenshot from my excel spreadsheet and here is a read-only Google Sheets link of the same spreadsheet.
I wrote a little bit more on my
, but basically you can easily redrill the 5x120 rotors to 5x114.3 by using two M8-1.25 bolts to bolt a 5x114.3 rotor to a 5x120 rotor, which I then used as a template to drill the holes with my drill press using a 1/2" drill bit. -- I had to use a rubber mallet and a combination of washers + lug nuts to massage the rotor onto the hub. 1/2" is probably too snug on the wheel studs, but I was able to get it to work fairly easily. I then used
Facebook Post
these 64.1 -> 70.1 hubcentric rings">these 64.1 -> 70.1 hubcentric rings" /> these 64.1 -> 70.1 hubcentric rings">these 64.1 -> 70.1 hubcentric rings
to center the rotor onto the hub. You may need to reduce the height of the hubcentric rings. If so, they can easily be sanded down.
holmesnmanny
04-17-2013 06:31 PM
g2_teg_
11-29-2010 08:39 AM
