Axle Beam basic info needed (Insight/Fit/CRZ/HRV)
1st Gen Insight KAWD swap going in and I'm using the rather new 2016+ HRV AWD rear axle beam. To match my front control arms I want to add heim joints inplace of the OEM bushings which is rather simple however when I look at the OEM joint they are at a 45° angle compared to the original Insight which are perpendicular to the direction of travel. I'm assuming this will take away some of the sway bar effect of the beam but that is purely a guess. Maybe someone can shed a little light on the subject to help me bake a better decision (pic with bolt in hand, the bolt is parallel to axle line.
