civic 2001 brake abutment shim
Hi
I had a very hard time to put the brake pad on with the abutment shim. I brushed it, grease it, and put new shim on and it wouldn't go in.
With both removed it was too loose. So I took off the bottom shim each side.
It fitted well.
Is it so bad to do so?
Thank you
It fitted well.
Thank you
Re: civic 2001 brake abutment shim
You talk about this page?
https://honda-tech.com/forums/honda-civic-2001-2005-78/
Thank you very much
Is it possible to delete that thread then??
Thank you very much
