Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Suspension & Brakes
Reload this Page >
5-swap on weird swap, EXPERT HELP NEEDED brain hurts.
Suspension & Brakes Theory, alignment, spring rates....
Old 05-07-2019, 01:25 PM
BongoBennie's Avatar
Default 5-swap on weird swap, EXPERT HELP NEEDED brain hurts.
I want 5x114 rear disc on my Insight and I'm on the cusp of figuring it out but need to answer a few questions, first What I have and know.
Honda Insight bolt on axle stub is 23mm
Honda Fit stub is 30mm
Integra Type R (and RSX/EP3) have a 30mm hub
Integra non R is same but 4 x 100 same as the Fit but wrong ABS sensor for fit, RIGHT one for Insight.
Are the rear discs in a GSR and Type R the same dimensions other than lug pattern?
Reason this matters is because of this rear disc kit for the Fit being available which uses all the bits from the GSR to mate to the Fit, I will make my insight axlebeam accept the Fit stub/TypeR (or RSX) hub/disc/caliper
and I have my 5 lug, I just need to figure out the Type R to GSR relationship
https://scarebird.com/index.php?rout...product_id=166
BongoBennie is offline
1slow_ej8
06-25-2007 02:18 PM
Tight Fit
Honda Fit
39
06-07-2007 11:24 AM
pkxfashion
Honda Fit
11-11-2006 10:14 AM
2fknlo
08-01-2005 01:12 AM
HapaHaole
09-20-2004 12:27 PM
Quick Reply: 5-swap on weird swap, EXPERT HELP NEEDED brain hurts.
  • Ask a Question
Question Title:
Description:
