Suspension & Brakes Theory, alignment, spring rates....
BRAKE PEDAL DOES NOT RETURN ON 94 ACCORD???
Old 02-01-2019, 11:27 PM
jdm_krish's Avatar
Default (SOLVED)BRAKE PEDAL DOES NOT RETURN ON 94 ACCORD???
My brake pedal does not return up when pressed down. I have to physically pull it back up(with ease). The brakes work/stop as normal. The pedal feels perfectly normal and not spongy when pressed. I don't think this model accord carries a spring on the brake pedal as far i can see from the service manual and brake pedal diagram.
Any help will be appreciated.
Old 02-12-2019, 07:51 PM
Steve at Heart
Bently_Coop's Avatar
Default Re: BRAKE PEDAL DOES NOT RETURN ON 94 ACCORD???
Sounds like you may need to bench bleed the master cylinder.
Old 04-26-2019, 06:45 AM
jdm_krish's Avatar
So it turns out the problem was the brake pedal adjustment on the brake booster rod. Re-adjusted the it so the pedal will be higher and now it works perfectly fine.
kirlous k
Suspension & Brakes
11
06-16-2018 04:18 PM
Pindanin
07-27-2013 02:42 PM
SikAuto
01-31-2008 03:31 AM
G2hybrid
08-09-2006 09:26 AM
mkalisky
05-12-2006 01:47 PM
Quick Reply: BRAKE PEDAL DOES NOT RETURN ON 94 ACCORD???
