hard race front camber arms on stock suspension dc2
i track a near bone stock dc2 integra ..it has SS brake lines, a 9 lb flywheel, hps front pads and i run hoosier r7s on the track. instead of going to coil overs right away i replaced the oem struts with gr2s and so far, i like the car alot and am learning alot.
i am tearing up the edges of my tires pretty quickly now since ive gotten a bit faster and managed to get moved to hpde2 with the group(s) i run with. i know i need to get some camber in to make these tires last a bit longer and give me some better grip...my friend says that running the hard race uppr control arms will rub with the stock suspension setup.
i was wondering if anyone has tried running a camber adjuster arm with a stock suspension setup. i am probably going to get the adjuster bolts from rockauto instead but was hoping to see if anyone has tried this before i pull the trigger.
Cool Cool Island Breezes. BOY-EE
Re: hard race front camber arms on stock suspension dc2
Adjuster bolts from rockauto? What is that?
Where did your friend say the HR arms would rub? On the springs? Stick your hand in there when the car is on level ground and see how much room is left. I doubt the arm itself will rub on anything...
People run camber kits on stock shaped lowering springs all the time.
If he means that adding camber will make the spindle rub on the spring when the car is raised off the ground...
maybe? But then it doesn't matter what type if upper control arms you use to increase camber.
I believe it will rub more or less where the ball joint on the a-arm sits in relation to the tire and the spring as well.
these are the camber bolts from rockauto i was talking about
https://www.rockauto.com/en/moreinfo...370641&jsn=413
when i say camber..i mean removing it (negative camber)
I've been running stock integra type r springs on bilstein shocks with the skunk2 front camber kit for 3+ years, no issues so far, bought my arms from another forum user and they had modified them to prevent slippage. Currently run about -2.5 to -3ish, but I had run around -2 degrees before. Mostly autocross, but I've done two track days on the setup
Yeah, the paint was taken off on the adjuster part of the arm. Two track days, and a ton of autocrosses and no slippage.
Slipping almost any adjustable ball joint would be very unlikely.
In most cases, you'd bend the spindle or hub first.
Years ago (pre-Fast and Furious to just a few years after) adjustable ball joint camber kits had a horrible reputation for slipping. I never had issues with the high end ones, but some of the cheap **** would cause all kinds of havoc.
you should be fine to run the hardrace front camber arms since the diameter of the OE spring is the same as a GC coilover or whatever.
FYI, the shoulder wear may not totally go away with more camber on that sticky of a tire.
I've had the perfect amount of camber on a 100 TW tire per my tire pyrometer and still got shoudler wear.
I went from 500 F and 600 R to 800 F and 600 R with a 24 mm rear sway bar to limit roll while maintaining rotation and the shoulder wear went away.
Dave-ROR
23
11-04-2010 06:01 AM
Blamm!!
04-07-2008 04:34 AM
p1driftfiend
08-12-2004 06:41 AM
