CRX insight brake swap
I have a 91 crx HF and im looking to lighten up the brakes a bit. From my understanding the front calipers, rotors, and pads as well as the rear drums from a 2000 insight will work?
With it being the HF model would early model HF finned aluminum drums be the better option over full insight?
Are there any issues i'll run into that i should be aware of?
From what im seeing the insight rotor is about 10mm smaller?
Any info would be appreciated thanks. I plan on doing a write up after i get it all sorted out with part numbers and weight comparisons for future reference.
Re: CRX insight brake swap
youre looking to lighten up the lightest car?
whered you hear this?
basically the same. different casting but not really different. ive never confirmed first hand the difference tho. it does look different on the outside so must be a different casting.
back to the first comment, why? its a weak car with a weak engine, and already high mileage.
ok
good luck.
Absolutely, light weight is the only reason any honda is even remotely fun to drive. Thats like asking why add more power to a zr1 corvette, isnt 755hp enough? Answer, its never enough haha.
There are threads everywhere. The only useful ones are on hypermiling sites or class specific road racing threads though. Im surprised you havent ran across the concept at least once with your 18,000 posts.
From what i've found the small secondary dust cover ring thats tacked to the backing plate needs to be removed, but it should fit like a glove other than that.
Who says any of that is true lol.
CRXherbie91
11-10-2008 10:24 AM
