Power Window Problem
Old Aug 11, 2002 | 09:16 PM
Conechaser's Avatar
Default Power Window Problem
One of the ladies at work bought their granddaughter a '89 Honda Accord. The driver side window will not go down, they were told that some wires were loose and that was the problem. I took the door apart and everything was hooked up, so the question is, what is broken so i can fix it. When you hit the switch to make the window go up or down you can hear a relay clicking in a little black box that says 'Power Window Control' and the motor doesn't make a sound, so is the motor bad? or the little balck box? Any way to tell for sure?
Old Aug 11, 2002 | 10:00 PM
Brandon's Avatar
Life is Suffering
Default Re: Power Window Problem (94Accord)
It is the little black box, which I believe is the regulator.
Old Aug 11, 2002 | 10:17 PM
Mike P.'s Avatar
25 Year Member
My mom's old '89 just had the same problem. I took it all apart and couldn't find anything, just like yourself. The shop replaced the 'black box.' Seems to be a trouble spot on these models.
Old Aug 12, 2002 | 02:37 PM
Chiovnidca's Avatar
Sometimes the motors go bad on those. Use a test light to see if the control unit is switching power and ground.
pldwelle
Sep 22, 2010 08:39 PM
rewerbcrx
May 30, 2010 05:14 PM
ramoneguru
Feb 11, 2010 08:51 PM
SmoothLude
Jul 11, 2009 06:28 PM
reemer
Nov 29, 2008 08:16 AM
