ABS Code needed!! Please help guys!
Old Aug 4, 2002 | 05:04 PM
VTECAcuraGSR's Avatar
Default ABS Code needed!! Please help guys!
Ok My mom has a 93 Accord SE and I the ABS light came on. I replaced and fixed the brakes, but it still stays on so I read the code. The ABS light blinks once and then the check engine light blinks 1 long and 5 short. So I assuming its ABS code 15 right? Does anyone have a helms that can look this up for me? Thanks!
Old Aug 4, 2002 | 05:35 PM
Chiovnidca's Avatar
Default Re: ABS Code needed!! Please help guys! (VTECAcuraGSR)
The ABS light will flash the ABS code. The check engine light will flash powertrain codes. Your ABS code is "1".
Old Aug 4, 2002 | 05:40 PM
Default Re: ABS Code needed!! Please help guys! (Chiovnidca)
Thanks for the info... But If I had an engine code, why wouldn't I have a check engine light come on also? Can anyone tel me what these codes are? Thanks!
Old Aug 4, 2002 | 05:51 PM
niedejb's Avatar
I've posted the codes on my website (under resources), but dont know if they're the same for this car as a F22b1. Most civic and prelude codes match em.
There is no 15 in my manual.
Old Aug 5, 2002 | 02:40 PM
bill-71SS's Avatar
Default Re: ABS Code needed!! Please help guys! (niedejb)
code 1 on the abs is pump over-run. most likely the abs pump will not build any pressure. very common problem on older accords. will need a new pump approx. 900.00
Old Aug 5, 2002 | 03:32 PM
Chiovnidca's Avatar
Default Re: ABS Code needed!! Please help guys! (bill-71SS)
Low fluid level or air in the system are very likely also. Try bleeding the ABS system first.
Old Aug 11, 2002 | 10:09 AM
This weekend I was looking for the bleeder for the ABS pump as one last attempt before the car no longer has ABS. Where the heck is it? I looked all over! Also does anyone have the procedure to properly bleed the ABS? Thanks!
Old Aug 11, 2002 | 12:06 PM
Chiovnidca's Avatar
It's below the battery.
Old Aug 11, 2002 | 12:32 PM
Below the battery? Why the heck would they put it there? Hmm... I will have to check it out. Does anyone know how to properly bleed the system?
Old Aug 18, 2002 | 03:33 PM
tjwebber17
Suspension & Brakes
Jul 2, 2011 10:15 AM
prelude_93vtec
Jun 28, 2007 02:58 PM
94ls
Sep 2, 2004 06:29 AM
andrewasf77
Nov 26, 2002 09:19 AM
