engine problem
Old Oct 21, 2002 | 10:20 PM
street_dreams's Avatar
Default engine problem
Well okay here we go . I got an 1996 Honda accord ex with an 1994 h22a swap in it . Okay well the problem is that the engine won't start . The engine turns over and everything but , there ain't no sparks from the plugs . I changed the whole distubitor and still no sparks . Then I checked the engine codes( did it befor and no codes showed till now) and it was a steady flash followed by 5 faster flashes . What this means I don't know (hopeing that someone would help ha ha ha ha ) thank you people for your time .
Old Oct 21, 2002 | 11:45 PM
RotaryBzzz's Avatar
Default Re: engine problem (street_dreams)
Sup Bra'
Damn...i wish i lived in Hawaii...no smog checks!!
the easy ones first: check plug-wire routing off the distributor. Check rotor inside distributor for contact/breakage.
I'm sure the morning crowd will help ya out bra'
Old Oct 22, 2002 | 06:00 AM
Stew Pidasso's Avatar
Code 15
Ignition Output Signal
missing or defective ignition output signal
taken from http://hybrid2.honda-perf.org/tech/codes.html
Old Oct 22, 2002 | 07:44 AM
carolinaACCORD's Avatar
Default Re: engine problem (Stew Pidasso)
are you using any type of aftermarket ignition?
Old Oct 22, 2002 | 08:23 AM
Default Re: engine problem (RotaryBzzz)
SUP hey well i checked all those so thanks oh yeah hawaii is yeah fun sun , beach , annd chicks
Old Oct 22, 2002 | 08:25 AM
so what dose that means ? dose that mean that my ignition aint getting any signal ? or my distubutor aint getting any signal from the distubutor? thanks man
Old Oct 22, 2002 | 08:27 AM
Default Re: engine problem (carolinaACCORD)
yeah I got an MSD 6A
1997accordSE
Feb 11, 2012 07:58 PM
oneslowstd
Oct 7, 2011 06:48 AM
adamyee
Oct 20, 2010 01:27 PM
mab546
May 2, 2008 11:40 AM
carproblems
Apr 17, 2008 02:49 PM
