Overheating issues...
Old Oct 29, 2002 | 05:16 AM
Accord_Munch's Avatar
Default Overheating issues...
Hello ..
Just recently, when I am stopped in traffic, the temperature in my gauge slowly starts to rise up .. up to the point where it is a slightly above the half way mark. My water pump and thermostat were changed this year.
What things can I check? I know my fans worked in the summer time, but I haven't checked them recently. Is there a way to make sure both fans are working correctly? Also, would it hurt to get a radiator flush, I have 127k miles on my car .. (1997). As soon as I start moving the temperature goes back down, it happened to me this morning on the freeway when I was stopped. (Accident). It was only 60 degree's out ..
Thanks ....
Old Oct 29, 2002 | 05:29 AM
AccordCF4's Avatar
Default Re: Overheating issues... (Accord_Munch)
Will that be your thermostat?
Old Oct 29, 2002 | 05:41 AM
Default Re: Overheating issues... (CF4 Owner)
I guess it is possible, but I had that changed this year ....
Old Oct 29, 2002 | 05:47 AM
AccordCF4's Avatar
It is worth a check, as it sounds like the cooling system is fine (fan, pump, radiator etc).
Old Oct 29, 2002 | 05:52 AM
Desslok's Avatar
If you are saying that it cools down as you drive, it probably is the fan. Check to see if the fans kick on. You can also test the thermostat by putting it in boiling water and see if it opens. For how cheap they are, I usually replace them with a factory part. I have had issues with the Stant ones you find at most auto parts stores, and after going through a few bad new ones I will never use one again.
Old Oct 29, 2002 | 06:10 AM
Default Re: Overheating issues... (sp)
Thanks for the responses, how do I go about checking to see if the fans go on? Is there something I can do to make them both come on??? How hard is it to get the thermostat out? I always thought it was a pain the **** on our 5th gens.
Thanks!
Old Oct 29, 2002 | 07:23 AM
autofrk's Avatar
to check if the fan is working, just let your car idle for a few minutes, the fan should kick on then turn off soon after it reaches operating temp... if you see this happening, i'm almost + that your thermostat is fine... does your coolant overflow? if your coolant is bubbling, it's a sign that your headgasket might be blown...
Old Oct 29, 2002 | 05:06 PM
Default Re: Overheating issues... (autofrk)
Well it turns out it was the fans after all, my fan switch has gone bad. So .. new fan switch going in tomorrow.
Thanks again Guys!
Old Nov 13, 2002 | 06:12 AM
Just and update, it turns out it was the fan switch that was causing the problem. I guess we have 2 fan switches, one of the switches went bad ...
Thanks people!
TurboTeG4
12
Dec 27, 2009 10:20 AM
BlackEkB20
Jun 19, 2008 01:54 AM
dcdcdc
May 3, 2008 12:08 PM
drewcandraw
10
Jun 8, 2005 10:37 AM
slowassR
Aug 27, 2004 09:37 AM
