A/C PROBLEM
I AM HAVING TROUBLE W/ A/C THE COMPRESSOR IS NOT COMING ON, IT'S A 90 HONDA ACCRD DX, IT JUST STOP WORKING THE OTHER DAY, I CHECKED THE FUSES BY THE FOOTREST AND ITS FINE. BUT NOTHING WHEN I TURN A/C SWITCH ON.
ANY SUGGESTIONS WILL BE APPRECIATED.
there have gotta be like uhh 50 million threads on AC problems... search is your friend....
If your compressor is not comming on, it is likely due to the fact that you have no freon in your system or you have a bad pressure switch or you don't have +12 going to the clutch or your ECU is not turning on the A/C
