Check Engine Light
Old Jul 4, 2003 | 06:43 PM
CaptainObvious's Avatar
Default Check Engine Light
I have a '95 Accord Lx and the check engine light is on. The Code it is showin is code 41 which says primary O2 sensor/ heater circuit. Is it most likely just my O2 sensor is bad or could it be the whoile heater circuit. If so about how much would that run me?
Old Jul 4, 2003 | 07:14 PM
preluder's Avatar
Default Re: Check Engine Light (CaptainObvious)
i would just change my sensor period
Old Jul 4, 2003 | 07:21 PM
im_the_teacher's Avatar
Default Re: Check Engine Light (preluder)
no i would not chnge the o2 sensor unless i know exactly wats wrong.....
1......o2 sensor is unplug
2.....u blow the heater circuit fuse.
3. u change oil, accidently spill oil over.
4...if everthing looks okay, i now change it.....
(never exchange parts.
Old Jul 4, 2003 | 07:22 PM
Default Re: Check Engine Light (im_the_teacher)
that preluder guy try to screw u man
Old Jul 4, 2003 | 07:28 PM
From what i can tell it was not unplugged but i will check the circuit. Thanks for your help.
Old Jul 4, 2003 | 07:44 PM
iam7head's Avatar
Could it be using aftermarket O2 sensor, i have the same code
Old Jul 4, 2003 | 09:32 PM
Default Re: Check Engine Light (iam7head)
u blown the fuse, look under driver fuse box.
Old Jul 5, 2003 | 10:15 AM
I Checked the fuse and went ahead and replaced it anyway but no go. I figure the sensor is probably bad because my car has 143k on it and i think it is original sensor. Does anyone know about how much a new one will cost?
Old Jul 5, 2003 | 10:40 PM
fluxion's Avatar
amin n'rangwa edanea
sorry to have to tell you this man..but it's $220, though you can get it for about $160 if you look around.
Old Jul 5, 2003 | 10:47 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by im_the_teacher &raquo;</TD></TR><TR><TD CLASS="quote">u blown the fuse, look under driver fuse box.
what is the name of the fuse anyway?
Old Jul 6, 2003 | 12:38 AM
Biznatch's Avatar
160? I just bought a new O2 sensor 2 days ago for 60$. It's just the OEM bosch one at autozone. I was getting the same code as you were and changed it and now it works fine.
Old Jul 6, 2003 | 05:22 AM
Default Re: Check Engine Light (Biznatch)
Sounds like a winner. Thanks
Old Jul 6, 2003 | 05:30 AM
YeuEmMaiMai's Avatar
I should change my sensor as my car now has 106K on it.....
Old Jul 6, 2003 | 05:50 AM
Chiovnidca's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">I should change my sensor as my car now has 106K on it.....</TD></TR></TABLE>
Not unless it's causing a problem.
Old Jul 6, 2003 | 06:27 AM
Default Re: (Chiovnidca)
One more ?...Would that O2 sensor not working cause my car to run really rich? Within the last week i have noticed a not-so-nice black buildup on my exaust and i wondered if that was it?
Old Jul 6, 2003 | 10:43 AM
Chiovnidca's Avatar
Default Re: (CaptainObvious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CaptainObvious &raquo;</TD></TR><TR><TD CLASS="quote">Would that O2 sensor not working cause my car to run really rich? </TD></TR></TABLE>
It can if it's output voltage is biased low.
vrotsos991
Honda Civic (2001 - 2005)
Jan 23, 2017 12:45 PM
Keevin77
Oct 28, 2011 06:18 PM
jdmkid_82
Feb 20, 2007 09:22 PM
HondaPH22
Jul 14, 2006 12:06 PM
Cashbrun
Oct 1, 2005 09:47 PM
